SOURCE: Error message 00004700h
This souns like a memory error, where the scan is too large for the pc to cope as other programmes running have taken their peice of your RAM, other than that, uninstall the diver in Add/Remove programmes, disconnect scanner. Re-install driver and re connect scanner when prompted and see if the fault goes away. Please rate solution.
SOURCE: Umax Astra 2400S driver for Mac OS 10.4.1 or Classic OS 9.2.2 scanner driver
You'll most likely have to use VueScan
Necesito el CD de instalacion
SOURCE: Problem installing umax astra 3400 on xp professional
Make sure you have the drivers for xp. If your unsure you can google them and be able to pull them up. try that and that should take care of the issue.Thank you for using Fixya.com
John C
SOURCE: Hi! I have problem with my old UMAX Astra scanner
Windows 7 support for the scanner is a UMAX responsibility. Most hardware vendors do not create new drivers for LEGACY items such as parallel port scanners. That scanner is likely 8 to 10 years old and it is unlikely any drivers will be written for it in WIN7
