Question about LG Flatron L1715S 17" LCD Monitor
Green Power LED is lit- But no image on the screen
I have a Flatron L1715S Monitor which I have replaced for a customer. When switched on the Green LED is illuminated, but no image appears on the screen other than the diagnostics icon or not connected message, which quickly disappears.
The Green LED stays illuminated whether the monitor is connected to a PC or not.
Could this be an internal circuit board problem, and if so can they be swapped out with replacements.
  • Anonymous Aug 13, 2008
    My screen went blank suddenly. Tried rebooting but still blank. When I press the green button, the image appears for a split second, then disappears. Checked the connections - seem OK.
  • ellff Sep 26, 2008
    I have L1715S flatron with the same problem (i.e. green power led is lit but no picture. If I turn the monitor off for a few seconds and then back on, for about a second I get a picture and then the screen goes blank again). Connections and PC check out OK. any ideas?
Hi, I have just repaired one of these with the same problem. Turned out to be a 680uf 25v capacitor that had failed. Capacitor was visibly domed. Easy repair with new capacitor. Hope this helps.
Posted on Sep 28, 2008
17" flatron crt monitor only green led blinking and tick tick sound .No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | LG Flatron F700P 17" CRT Monitor
When i boot up the screen lights up for aa few seconds then go's off
dbartholo630, Your CCFL back-lit lcd monitor no different than any other brand in it's basic use of technology, design, and operation!! Your 5 to 7 year old unit needs work (repair/refurbishment) of it's power supply. Yes, it could have swollen, leaky electrolytic filter capacitors on the switch mode power supply that will need replacing with new one's to get it up and running again???? Read fixya "profiles" and "testimonials" of the following fixya tech's: "budmrtn" "buddymc" "12fixlouie".
Only you will determine if you will DIY fix or just trade in for new wide screen unit. Hope this was of some use to you. 12fixlouie
Sep 07, 2010 | LG Flatron L1715S 17" LCD Monitor
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
I am using the LG Flatron L1715S 17" LCD Monitor as an external monitor for my lap top as the screen on my lap top is toast. What I cant figure out is how to size the screen to fit the proper dimensions of...
The FLATRON L1715S color LCD monitor with auto-synchronous support, plus it is PC and MAC compatible, has features like simple one button auto setup and is VESA DDC2B, DDC1, Plug and Play compatible.
use the 'Auto' adjust button on ur lcd..
howevr, if u want to configure using win xp/vista..right click on ur desktop->properties->settings->increase the 'screen resolution' to minimum: 640x350 or standard: 1152x864 or maximum: 1280x1024 @ 75Hz..
best is to seek professional advice of ur system admin/vendor....
Nov 05, 2009 | LG Flatron L1715S 17" LCD Monitor
My Flatron L1715S monitor works fine except that numerous small harvest flies find their way under the screen. Whilst they may be a source of amusement when alive they certainly are not when dead! I'm a...
you have to disassemble the lcd screen, to remove that.Remove the cover,power supply with casing, disconnect the VGA connector going to lcd, then disaasemble the lcd screen. It a little bit treaky about that you have to be careful not to broken the backlight and lcd screen.
Jul 27, 2009 | LG Flatron L1715S 17" LCD Monitor
LG L1715S TFT power issue
Change out C202- 680 uF 25 Volt electrolytic capacitor. Replace with 25 volt or higher. Observe proper polarity when replacing cap: (-) goes to the side with the black mark, check old cap before removing it to see. I just fixed the same monitor today.
Dec 04, 2007 | LG Flatron L1715S 17" LCD Monitor
No power to the monitor
You can try buying a new power cable (they are very cheap) Also sometimes this sleeping monitors just "come to life" after some time without using them but when this happens it is usually a bad sign.
Mar 06, 2007 | LG Flatron L1715S 17" LCD Monitor
No picture for a while, green flashing light
That is a defect with those monitors...you should get the returned to the store...if you can't then you may have to do some soldering dude...it is a power issue with the monitor itself...you will need to find the replacement capacitor inside..but still the best advice is to return the product
Oct 31, 2006 | LG Flatron L1715S 17" LCD Monitor
LG Flatron L1715S 17" LCD Monitor Logo
466 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
