Question about Gemini XL-500 Turntable
Gemini xl 500
Hi, my gemini's pitch is off, it goes up and down eventually..can this be repared?
  • jay119 Jan 24, 2009
    Hello mate, havnt used my gemini xl 500 for years, but decided to get them out the other day.
    I have the same prob as you, it seemed like the pitch control would just change by itself. You would get 2 tunes inline, and then they would just come out of line
    did that solution work for you?
    Would be grateful if you could message us back and let me know your progress
    cheers.
On top of the pitch control there is a small hole, in this hole you can use a small screw driver  and turn it left and right to free any dirt inside this is the master pitch control
Posted on Aug 16, 2008
Where to get a needle for Gemini XL 500 II
Look at the cartridge make and model number fitted. Put that into Google and the type of stylus needed will show up.
Jun 29, 2014 | Gemini XL-500 Turntable
How can i connect my Gemini Turntable which has a ground cable connection to a device that does not have a ground cable connection?
Hi, slip the ground cable in the side of the rca connection to the device without earth point.It makes no difference if it goes in the left or right jacks. styluscity@gmail.com
Sep 06, 2010 | Gemini XL-500 Turntable
I need a replacement cartridge for the gemini xl 500 ii series and i can't seem to find it in any stores or online.
Maybe this will be of help?
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=GEMSXL500II
Aug 03, 2010 | Gemini XL-500 Turntable
Issues with turntables picking up speed when trying to time start off. It's hard to match beats when the table does not start on cue or slowly try to catch up to speed. What's wrong with them?
This seems to be a pitch control issue. controller,
replacing \t,could be worn over time,
SL1200 Technics - if you want a solid long lasting excellence of sound reproduction for many years to come,
I had the same pitch control issue,
happened on one of my decks so I replaced the controller and good to go from there,
Another important tip -
never lubricate the controls sliders with any thing apart from the correct greases or oils applied by the manufactuer,most people dont think of the damage caused by the cleaners they use ,some aerosols eat away the fine oil that lubricates the pitch control sliders making them dry and brittle eventually cracking producing odd random performance issues,
hope this helps,cheers Misterdj
Apr 08, 2010 | Philips gemini XL-500 II Turntable
Sound wavers (speeds up and slows down)
you need to replace the Pitch controls. I'm presuming it is a sliding pitch control. Use the Red start stop lights that reflect on the rotating wheel. put the pitch in center 0. does one row of the dots on the wheel stay completely still.now just turn it up op down a bit until it starts to move the dots slightly. now watch the dots now while there moving. Do they fluctuate they should be smoothe. do this on both decks to find out which one is fluctuating.
Jul 10, 2009 | Philips gemini XL-500 II Turntable
How do you hook up gemini xl 300 turntables to a gemini pmx 500 mixer
red n white phono leads from deck 1 to channel1phono ports on mixer
red n white phono leads from deck2 to channel2 phono ports on mixer
then output out to amp
Jul 06, 2009 | Philips gemini XL-300 Turntable
Turntable will not hold pitch,speeds up or slows down.
try replacing the drive belt with brand new one and see if this improves the situation
May 27, 2009 | Philips gemini XL-500 II Turntable
Gemini XL-500 Turntable Logo
611 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Don Hart
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
