Question about U-Line Icemaker
Ice Maker Hi, You sound like you know an ice maker. So many of the answers I've gotten were just guesses and we've already done that. One answer was all about my refrigerator and cleaning the coils, obviously didn't read the question, thoroughly. This unit seems to be short-cycling. If we turn the ice thickness all the way up, it starts to freeze then immediately defrosts. The unit isn't even four years old, yet. The unit worked perfectly until we moved it to replace the leaking water line. Because of this everyone suspected circuit board (replaced that!) and freon (checked and ok!), but it seems like we're overlooking something. How do we get the water tray to freeze and stay at a freezing temp long enough to make ice cubes? Joy Brown
    Genius:
  • 2,035 Answers
The heating coil in the unit may be activated which cause water not to freeze....
To know were the heater is located .Please check on this link:
http://home.howstuffworks.com/icemaker1.htm
Posted on Aug 10, 2008
I'm looking for a lid for my old ice cream maker. Where can I get one?
I already answered your question. Don't ask twice - it won't get you an answer any faster. You need to provide more information - make and model. You can do a Google search and you can also go to eBay. Say if you want an actual vintage ice cream maker or just an old fashioned one. Here again, do a search for what you want.
Mar 02, 2015 | Ice Cream Makers
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
My IM115 frigedaire ice maker, doesn't seem to be making ice fast enough
The key to ice production is temperature, so if the unit is running at "0" the fan also has to run to cool faster. That a good look at these items and see where the issue may be. In this environment point blank information is the only way anyone could assist you. Lack of information causes no response or incomplete answers. Check the temperatures also check the ice maker for pealing or flaking mold issues. Good luck
Aug 25, 2014 | Frigidaire Im115 Im115 Ice Maker Kit
Ge refrigerator gts22wcm ice
Inspect the ice maker itself, sounds like either you have a jammed cube or your ice maker is not turning on heater to eject ice cubes from mold. If heater is the failure - replace ice maker. If unit is jammed, clear the ice maker mold and allow to cycle to see if damage was done to gear or ice production is restored.
Good Luck
Oct 23, 2013 | Thermador T36IT71NNP (196 cu ft) Bottom...
Ice maker won't eject icre
you need to replace the ice maker because the heater inside the ice maker is broken thats way its not ejecting the ice
Jan 18, 2013 | Maytag Refrigerators
Icemaker is warm and stopped making ice
The ice maker has a heater that comes on just before the ice dumps to assist in releasing the cubes. Sounds to me that you need to unplug the ice maker and begin a search for a new replacement ice maker=> 67004-S Ice Maker Assembly
You may want to call them to see if the ice maker is rebuildable because the price for the ice maker is really high. If you have questions I will be here to answer them for you, Thanks Sea Breeze
Jul 12, 2012 | Refrigerators
ICE MAKER
There will be several items to check that can get your ice maker back to operational. First you will need to see if the ice maker is refilling after each batch. Us a light or feel to see if ice maker is empty from the last cycle. If no water is in the ice slots use a cup and pour tap water into the empty ice slots to about the top of the ice maker. Allow water to freeze and if the cube's dump into ice bin. If then water does not refill the ice maker I believe the dual water control valve=> 67005154 Dual Water Control Valve is at fault.
Click here=>
Whirlpool's Ice Maker Harvest Cycle
most of the information you are looking for is on the page above. I will let you begin by going to that link and saving the Whirlpool Ice Maker Troubleshooting PDF. Once you read over that material and are able to use an ohm meter we will move to the test points behind the ice makers front cover. Ice Maker have about a five year average life cycle and many times it is more cost effective if you replace the=>
D7824706Q Ice Maker Assembly or click here=>
D7824706Q Ice Maker Assembly In the clip below you basically have all the solutions in this one You-Tube Movie=> Ice Maker Repair I believe this is one of the better Whirlpool Ice Maker related video's and covers most all of what you need answered. I will be here to answer any questions. Checking the ice maker mold heater by testing the L and H test points (should show about 72 ohms of resistance) Testing the Ice Maker Timer L and M test points should show around 4400 ohms of resistance Motor You also can answer from the ice maker by testing just what condition your water control valve coil windings are by placing the test probes in the N and V test points where you should get between 150 and 350 ohms of resistance. I will be here to answer any questions you may have, If this solution is helpful please rate my solution, Thanks Sea Breeze
Jan 06, 2012 | Jenn-Air JFC2087HRS Side by Side...
Hi, Just replaced the optics on the Whirlpool icemaker. They seem to be working fine but still no fill and no ice. What a pain.
Below I found a website that might answer your questions, this is not a big problem.
Optics Video
Below the video is a picture of the board, it shows you how to jump the circuit to advance the ice maker, this also can be done without removing the board. By using a standard screw driver the make contact between the black and black with white tracer. This will advance the ice maker into a harvest mode and prime the ice maker.
Good Luck
Aug 14, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Salton ice cream maker manual
I downloaded a manual for the ICM21, same picture as yours, today, August 2009, from kitchen.manualsonline.com
Click on frozen dessert maker under Member Contributed Manuals.
Click on Salton frozen dessert maker
Scroll down to Comments, get this manual
Click on instructions
Salton ice cream maker pdf
The one there is for the old ICM21 ice cream maker.
Jan 16, 2008 | Salton ICM-21 1.5 Quart Ice Cream Maker
Ice maker not dumping ice
Make sure the freezer is at least 17 degrees or colder (colder is better). If you have a square cover on the end of the ice maker see if you can pull it off and press on the gear face (don't turn just press). That may clean the electrical contact springs and get it working again. Basically if ya got water, 17 degrees or colder you will get ice. Other than that the ice maker motor module is likely bad (broken gear, etc.). Pretty common.
Aug 17, 2006 | Frigidaire FRS26KF5C Side by Side...
U-Line Icemaker Logo
110 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
