Question about RCA 27F634T TV
Tv stopped working
My tv has stoped working when we try to turn it on a red light flashes for a few min then it stops and stays sloid red and tv wont come on what is wrong with this We were watching tv when all of a sudden it just shut off. we tried turning it back on and then unplugging it and leaving it unplugged for a few hours and then plugging it back in. the only way it will turn on is by plugging it back in. and the only thing that happens when plugging it back in is the red power light will flash but whne the power light becomes solid there is no picture noo nothing....what hapend to it?
    Genius:
  • 1,269 Answers
Have you played with the TV settings using the remote?
Here's some suggestions from this link:
http://en.allexperts.com/q/TV-VCR-Stereo-1749/RCA-TV-Won-t-2.htm
It says there:
Have you tried the channel up and down buttons? They should turn the set on, also.
Here is what I suggest.
ONE: Do a hard reset. This will clear any corrupted soft codes. Unplug the power cord for 4 hours. Then repower.
TWO: Study the owners manual. You can download if from the rca.com web site. There may be some instructions there that are pertinent.
THREE: If the power protection circuit has taken over the set due to some shorted conditions internally, then the hard reset should allow you to turn it back on but if the condition remains, it will just go into auto off again. This means there is a hardware problem that is locking up the protection circuit. Since there are so many possible areas in the set that can cause this, you will need a service tech to do the hands - on diagnosis for it.
FOUR: You can fix it once we know what exactly is wrong with it, but since there are so many possibilities, that is the first problem: Just finding out what is the real problem.
So, maybe these ideas will get you headed the right direction.
Now, if there is a lock on the power function, it will need to be reset; there is a resetting procedure in the owners manual, I think.
Posted on Aug 10, 2008
    Genius:
  • 1,011 Answers
Dear sir/madam,
It may be a cold solder joint. If so, you could fix it by yourself. Have you done a loose connection test? Just bang the set with your hand or fist on the side,, back or top to see if you can restore the functionality. If so, then you might be lucky enough to keep in working. If not, you may have to go in and find the poor connection and solder it back down (or have it done). This is a minimal repair job once you have found the bad solder joint or loose connection.
thanks
good luck
    Genius:
  • 2,920 Answers
The power supply went out on the tv .its common it would be cheaper to buy another tv
    Master:
  • 623 Answers
Your picture tube is busted have it replaced by a tv technician....
  • RCA Master
  • 19,396 Answers
The TV safety switch it is turning tv off because of a short or overvoltage, this can be caused ba a blown capacitor, an IC or another component on TV board, let me know if you get any error code.
  • Ginko
    Ginko Aug 10, 2008
    You will probably need to take your tv to a technician for repairs, as unit must be taken apart and component on board tested. You find service number printed on last pages of tv owner manual.
  • Ginko
    Ginko Aug 10, 2008
    Hey guys how do you know it is power supply or tube? there is no error code or flashing code published, please be serious....Regarding the user problem, check if there is a code on display, or if led blinks a certain number of times, so that we can understand where problem is located.
  • 594 Answers
I need the make and model of your television.. usually the red light blinks out a code. i need to know how many times it blinks as well. so i can find out what code it is producing.
  • Cameron Viseth
    Cameron Viseth Aug 10, 2008
    ok the RCA tech said that there is a short in one of the boards. you will need to take the t.v. in and have it repaired... Look on your owners manual to make sure that it is still under warranty. or you can buy a new t.v.
My Samsung TV doesn't show a picture, when there was a picture audio and remote not working. Which boards need replaced?
If there is no audio then most likely your main board. If your red power stand by light blinks less than 3 s then its the M/B. If its more than 3 s then its the P/B.
Sep 03, 2015 | Samsung PN50C550 50 in. TV
Toshiba 62hm84 dlp
Sounds as though the system may have overheated. Do you regularly check the filters and clean them? An airduster can also help to blow dust out of hard to reach places.
Apr 14, 2014 | Office Equipment & Supplies
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
I have KDS-50A2000 Sony SXRD Projection TV. Serial #9028985. It was working fine then a few days ago I went to turn it on and the red power light was blinking 4 times and repeat... I then opened the lamp...
hello, this can cause the red power light to flash 3 time also if the lamp cover is not fitted securely this can also cause the light to flash 3 times 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped hope it helps
regards
shaun
Jan 03, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Printer does not go
After few head cleaning, ink counter running low, so ink ligh (red) flashing. Then ink counter runing out, so the light stayed on. After replacing both of ink, red light stayed on, because the compatible ink (chip) not recognized by printer. Check epson status monitor. Use original ink or refill and reset ink level counter.
May 26, 2010 | Epson Stylus C60 InkJet Printer
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
Tv troubleshooting
I have a 61" JVC that just stoped working. I turn it on and nothing bu the blue light stays on and the red light blinks 8 times and then the blue light joins in.
Oct 30, 2008 | JVC HD-61Z575 61" Rear Projection...
Sony WEGA LCD TV Model KFE50A10 wont turn on
It turns out that the number of red lights flashing, relates to a partiuclar error problem. My TV was flashing 4 red lights, pausing , then flashing again etc etc. This particular error meant that one of the five fans within the TV box had stopped funtioning. So the TV has gone to the repairman today. I was advised by an operator at the SONY STYLE CENTRE that such a repair would be considered as a genuine fault and that SONY would pick up the tab. I live in hope
Apr 01, 2008 | Televison & Video
RCA 27F634T TV Logo
226 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
