Question about Hunter 52" Ceiling Fan With Light And Remote Control
Having problems mounting ceiling plate
I am trying the hang the ceiling plate but there is only a small piece of wood behind the ceiling box and I can not put two screws in the outer most holes. I can only put screw in two holes close to each other? What do I do? I am hanging a hunter 20761 Stratford II 52 in fan
  • jtcharneske Aug 10, 2008
    I am actually trying to mount the plate to the electrical box and I can not screw the two screws into the outer most holes in the electrical box since there is on a small piece of wood on one side.....this is some new mounting for Hunter fans. Not the typical mounting where you have the bracket and slip the ball/rod into the mounting? I am lost
    I know what has to be done...I am not sure how to do it but it appears it is the only way.
    Thanks guys!
  • 2,071 Answers
Just put face plate holder extension.try this option..
Posted on Aug 10, 2008
    Master:
  • 521 Answers
Use the drill and make the holes where you want to make it fit exactly and tightly ,this is the common problem faced by the client many times and this is the easy and safe solution .
  • 319 Answers
You must absolutly have a better support system than what you describe.
You may have to install a support bracket.
Please see this article for existing home installation of a support system.
Regards,
Brian
  • Brian Berndt
    Brian Berndt Aug 10, 2008
    Please look at the link in my solution!
    Brian
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Click this link for instruction manual....check out....
http://www.belowcostappliances.com/info/fans/owners-manuals/wet-light/light-fixture.html
thanks
good luck
    Genius:
  • 1,269 Answers
You need to cut a bigger wood and if there's no hole on the other end, you need to use an electric or battery drill to create another hole on 4 ends to make it tight.
  • 594 Answers
Look at your fan. most of the time your fan will have 2-4 screwes in the top of the fan. on the plate the holes you are regarding to may have a big end sliding down to a small end... if this is what it looks like than the outer holes are for the fan to sit into... take the plate down and put it on top of the fan like it would be if it was hanging and see if the screwes in the top of the fan match up with the ones in the plate. if so than you onyl need to the 2 screwes to hold the plate. the other holes are to hold the fan in place on the plate.
  • Cameron Viseth
    Cameron Viseth Aug 10, 2008
    here is a link from hunter for the installation for your ceiling fan...
    copy and paste it into your browser.
    http://www.hunterfanhq.com/hiw-prod/orde...
    also if you can not put the screwes into the out part of the plate and make then go into wood than take a screwes and put the plate in place. after that scrwes the screws into the cieling at all 4 spots.. once that is done take them back out... they have what are called drywall insertes. they are a plastic tube with threads inside.. get 4 of thoses and put them into the ceiling. after that put the plate back up and put the 4 screws into the dry wall inserts. also put the 2 scrwes into the ceiling beem or peice of wood for extra support.... than go ahead with the instructions.
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
Our ceiling fan is having a major problem it has an ac hum that goes right through you can you please help us to solve this problem?
Put a small piece of card board between the mounting bracket and the celing/outlet box. this will dampen the noise, and hopefully fix your problem.
Jul 11, 2010 | Aloha Housewares (93645) Ceiling Fan
Fix a fan that is hanging loose from ceiling. Do I
Hi .. no you should be able to just drop the canopy cover ,, and be able to see what is loose at the ceiling .. it may be the mounting plate where it connects tio the ceiling box.
Jun 26, 2010 | Hampton Bay 24002 Ceiling Fan
Receiver installation issue
Most of these fans locate the receiver on the mounting plate (metal part fixed to electrical box where ball hangs). The canopy (decorative part that covers the wiring on ceiling's electrical box) has enough space to hide it. I presume you're missing the manual, so install the fan and slip the receiver in the plate, right between the electrical box and the ball, everything's color coded, securely wire cables from ceiling to power cables in receiver and cables from the receiver to the fan. Slide canopy up and securely fasten with provided screws. Good luck!
Nov 01, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Similar problem: Does Hampton Bay Vaulted Ceiling Mount exist?
Ok so here is the deal. No there does not seem to be a Hampton Bay specific mount. The mount that comes standard in most of the Hampton Bay fans can handle the angle of most standard (read: small) angles. I do not know if it will be the case with all Hunter products, but the adapter for the Hunter fan that I replaced, worked with my new Hampton Bay. So now, I have from the downrod up is from the original Hunter fan. Hope this helps.
Sep 16, 2009 | Hunter Vaulted Ceiling Mount - Bright...
Mounting a Hampton Fan Model 52-CL
hello d,
1. yes, with the proper rod, longer wires(3,4) and the blades must be over 2.5 metres (8 foot) above the floor.2. you need the proper type box; the mount/s and ball; the longer wires (3,4)with slender but connertors; and especially the safety pins, etc. with the proper rod, the fan will hang straight. and about 3 chock hours to do this here task. hope this helps.
Jan 16, 2009 | Hampton Bay 52 In. 5-Blade Fan, Aged...
Remote receiver doesn't fit
ok since you have the power off move ceiling fan box electrical box over place remote above the electrical box with the antenna sticking out replace fan power up you might have to go into attic to place the remote sensor and antenna down to outside of fan i had the same problem myself i made a cut in drywall ceiling big enough for sensor unit let the antenna hang out placed up there
i used a wall plate cut in half to match the hole i just made or you dry wall back up but if remote goes out theres now no way to get to sensor unit
little cut in drywall place sensor threw antenna hang down put plate over hole
May 26, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Mar 10, 2008 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton fan
You are probably missing a part. There should be a mounting plate...usually round...that attaches to the ceiling or electrical box. The mounting plate would have small tabs or a lip around the edge with threaded holes for attaching the cover.
Jan 16, 2008 | Dryers
Hampton Bay 54in. Covington with remote control
Make sure the power wires from the ceiling mount are still in the electric box. Then have them come from the side near the screw mounting area. In otherwords, not through the center hole. In the center of the black metal part - there is where you put the reciever. It will fit literally resting on the black metal.
Aug 31, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Dryers Logo
133 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
