Question about Lexmark Wheelwriter 15 Series II Typewriter
Selectric II typewriter
Inherited his correcting typewriter. When we turned it on the return is stuck and keeps returning
  • Lexmark Master
  • 3,594 Answers
If you know how to remove the cabinet and dust covers spray every moving part with WD40 especially the cams and parts under the R. dust cover.
DickyO
Posted on Aug 11, 2008
The return key sticks on my Selectric II
Under the R. black plastic dust cover there is group of cams and arms spray the two sets of arms and the cams with WD40 this shouls free up the arms.
DickyO
Mar 09, 2010 | IBM Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II keeps returning to right.
Check the pitch lever on the top L. of the cabinet it may be in between positions.
DickyO
Sep 08, 2009 | IBM Office Equipment & Supplies
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric II-return goes past the margin stop
The margin release mech. is probably gummy and allowing returns to go past the margin. If thi is a dual pitch machine see if the pitch selector lever will move easily. If not use some WD40 on the margin rack.
DickyO
Mar 11, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II won't return completely
The machine is probably gummy. If you know how to remove the case do so, get some WD40 and spray everything that moves espesially the stuff on the outside of the rt. side frame.
DickyO
Sep 28, 2008 | Lexmark Wheelwriter 15 Series II...
Return key is stuck
Need more info. Many different possibilities.
Aug 11, 2008 | Office Equipment & Supplies
IBM CORRECTING SELECTRIC II TYPEWRITER
Is the key stuck in the down position? If you pull the key off you should see a spring underneath. Maybe out of position or damaged.
Aug 10, 2008 | IBM 3500 Typewriter
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
Lexmark Wheelwriter 15 Series II Typewriter Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
