Question about Lexmark X83 All-In-One InkJet Printer
Printer not commicating with PC
I have had this problem before and have always solved it. This time I can't. I have followed all instructions.....unplugging the cable and plugging it back in and rebooting the computer, etc.
Help
Thanks
Kurt
  • Anonymous Aug 25, 2008
    i have not been able to print off screen since switching to aol from msn
I have the same problem. I know now that Lexmark X83 does not work if you have Windows Vista as your operating system (at least not yet...).
Posted on Sep 02, 2008
Why won't my printer print more than 1 Page at a time?
Please go to your printer preferences and select page setup choose default setting and customize other page setup then click apply and restart your PC. If not done then follow the instruction.
1. uninstall your present printer driver.
2. Restart your pc.
3. Install your printer driver again.
4. Restart your pc.
Hope it will solve it.
Thanks
Apr 07, 2016 | Epson Stylus Photo R3000 Inkjet Printer
Two faint white horizontal lines
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
Jan 09, 2014 | HP LaserJet 1000 Printer
Keeping getting commication not available
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 02, 2012 | Lexmark X2600 InkJet Printer
Im always getting an error msg.general error..Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on....can you...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 26, 2011 | Office Equipment & Supplies
Richo Aficio g7500 printer error 950. Replaced new ink woill not recognize the new full cartridge???
HI there try this.
1. try to reset the printer & clean the printer head by some alcohol and the see what happend. If not solve then follow the step 2.
2. Uninstall the printer driver and restart the PC . Now again install the printer driver and try. I hope this time your problem will solve.
Thanks. Let me know the result.
Nov 28, 2010 | Ricoh Aficio G7500 Printer
Ink pad full
Try to follow this steps:
1. Long press the power button for 10 seconds.
2. While pressing the power button disconnect the power cord at the back of your printer.
3. Turned it On again then try to print.
If it can print, Every time you print just always perform that solution because your printer are meet the maximum number of copies to be print that's why the problem are back. You can also downlaod the reseter program of that printer to permanently solve that problem.
May 29, 2010 | Epson TM-T88III Thermal Printer
How to scan to computer
please follow the onscreen instructuions from the below mentioned URL and hopefully this should fix the problem
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01585107&cc=us&lc=en&dlc=en&product=3571753
if still the issue is not solved then print a test page from the below url
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01419134&cc=us&lc=en&dlc=en&product=3571753
if still the issue is not solved then follow the below steps to reset the printer
without turning the printer off remove the power cable from the back of the printer
wait 20-30 second and plug the power cable into the back of the printer
if the printer is not already on use the on button to turn on
if still the issue is not solved then get back to us we will help you..
Good luck.
we are always there for you to solved your issue.
hope your issue gets resolved
thanks
regards
hamid
Mar 01, 2010 | HP Deskjet F2210 InkJet Printer
My printer will not commicate with my computer
I had the same problem with my X5410. I had to uninstall the Lexmark software. Then I turned ON the Windows Firewall.
I then re-installed the Lexmark. Only took about 6 hours
to figure it out !!!
Good luck
Jan 18, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My computer will not communicate with the internet
Try following the troubleshooting steps for overall dead connection here, and for USB connections between the PC and Modem here.
Dec 23, 2008 | HP PAVILLION DV6841TX PC Desktop
Does not print
There is problem with your printer head socket, service the printer if problem is solve then ok otherwise change the head socket.
Mar 10, 2008 | HP DeskJet 920c InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
