Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Digital readout displaying F7 E6
Unit stop working while cooking on the stove top,using all burners.To much heat ? to much moisture?.
  • Fretgames Aug 11, 2008
    I did as insructed did not seem to work. same f7 e6. thanks anyway.
  • 218 Answers
Why is stove top displaying symbols not recognizing pots? Had stove 6 weeks, pots are correct and been used on this stove. Displaying on all 3 cooking areas.Can I correct it or is it faulty?
lets review this
please advise readers
maker of cook top so they can find the user manual
model or how old helps also
its not a gas cook top
you have the right type of designed pots for that cook top
but you get no heat radiating to the pot base
when pot is in contact with the heat area
Aug 17, 2016 | Cooktops
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
My oven shows an E7 on the control panel of my Maytag che9800bce
the tech sheet says " Function key shorted or stuck button" ,I suggest you to try to play around with the buttons and test the bake element for continuity
Mar 07, 2013 | Kitchen Ranges
E6 displaying in Induction cook top
my problem is E6 code & 1 or 2 minutes automate stopping
Jun 05, 2012 | Microwave Ovens
Clicking on stove top will not stop
Unplug the stove top for a few days, and let the burner switches dry out. Sometimes this is caused by moisture getting into the switches from a boil over, or from someone cleaning the stove top. If your unit still sparks after a few days then you will have to replace the bad burner switch, or switches. I am assuming that you are talking about a cook top that is sparking all the time, and not about a cooktop that is sparking, even after the burner lights. If your burner is still sparking after it lights, you usually have a bad spark module. Good Luck, Appliance Specialists
Jan 17, 2010 | GE Kitchen Ranges
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
I was cleaning stove top and all of a sudden the electrode on thr front right burner started clicking and the middle burner in the rear clicking also and will not stop.
IWAS TOLD TO DRY IT OUT WITH MY VACUUM BLOWER WHICH DID NOT WORK THEN HE GAVE ME PLAN B.WHICH WAS TO COOK BREAKFAST EVEN THOUGH IT WAS STILL CLICKING AND THE HEAT FROM THE STOVE WOULD PROBABLY DRY IT OUT......IT DID AND IT STOP CLICKING!
May 26, 2008 | GE Kitchen Ranges
GE Profile Gas Range oven turns off
I just read that the electronic panel malfunctions due to rear burner use. Now, I know that mine gets REALLY HOT in between the back burners (where the heat exhaust for the oven is) whenever I bake/broil. I am guessing that it can cause the same malfunction fromt he oven, as with the backburners. Whenever I use both back burners, mine shows F7 E6, too. Unplugging it for the night or just waiting til the beeping stops and then clearing it works... until I cook again. I read that the replacement part for the control panel is about $300 and another $200, more or less, to install it! I think this is more like a recall or manufacturer's problem. I have read plenty of complaints and I think GE needs to make a call to fix them!!
May 12, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
143 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
