Connecting a wii to a toshiba tv model no. 28n33b
My wii asks for a video and audio inlet but there only seems to be outlets
I was having exactly the same problem with my toshiba 28N33B until 2 minutes ago! I searched the internet for the solution but only came accross your unanswered question, i hope you've sorted it by now anyway as its been 6 months, but for all those with a similar problem:
You cannot connect your wii to AV OUTLETS only INLETS! At first glance it appears that the 28N33B only has outlets....BUT actually, the AV inlets are (stupidly) hidden behind the speaker to the right of the TV screen (as if you were looking at the screen) - they are separate from all the other ports at the back of the tv.
For anyone looking for Toshiba inlets on other models - my advice would be to take a deep breath, push the telly out from the wall and take a GOOD long look all over the tv for three circular ports coloured red, white and yellow that have the words 'in' or 'inlet' etc printed near to them. You're wasting your time trying to connect the wii via the audio output, it just wont work, no matter how much you re-tune the tv (I know from experience! grr!)
Right, i'm off to play mariokart, hope this helps somebody!
Sara
Posted on Feb 15, 2009
Hook up to the Wii
Alright so first of all, you should have gotten a cord with a big, grey power brick attached to it. Plug the end in that goes in a outlet, and the other end should hook up to one of the outlets on your Wii console. Then, there should be a cord with three branches. They should be colored red, orange/yellow, and white. On the back/front or on the cable box for your TV there should be plug-ins that are colored either red, white, green, blue, or orange/yellow. The specifications should be written under the outlets (visual, audio, etc...). Plug the white and red part of the cord in to the "audio" outlet (on your tv). The other cord (yellow/orange) should plug in to the outlet that is labeled "video" or "visual" or "screen" or something along the lines of that. The next step is pretty simple. Your Wii (should have) came with a sensor bar. It is thin, long, and black and has a very long, very thin cord attached to it. Plug one side of the cord into your Wii console, and the actual sensor bar goes on top of your TV. There are small, sticky rectangles that help with the sensor bar sticking to your TV. After you've done all that, your Wii is ready to go! Just push the power button and your ready to start playing!
Nov 28, 2013 | Nintendo Wii Console
I have a magnavox 32MF301B. How do I connect a wii to it? I've tried matching colors of cords and it didn't work.
Don't connect colors. The white and red cords should go in the "audio" outlets in your tv, and the orange/yellow cord should go in the "video" outlet in your TV.
Sep 29, 2013 | Video Game Consoles & Games
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
I disconnected my TV when we were having work done in the house. At the time I had no trouble getting Sky. A new connection to the dish has been installed but I cannot get onto Sky. I have checked the...
Hello
To synchronise with sky you have to resynchronise it, as you have disconencted it and reconencted with new one. The sky remote codes for Toshiba to check with are:
28W93B 2563DB
Toshiba
156T9B 175T9B 213T4B 2151TB 2197DB 2512DB 2535DB 2539DB 2550TB 2563DB 256T9B 28Z27B2 2812DB 2857DB 2835DB 2873DB 2877DB 28W93B 2500TB 3357DB 573DB 2879DB T1510T8 25001TB7 32DB 32M8DB 2855DB CT9689 2939DB 40PW03B MV40PWA 32M9DB3 2893DB 32317B 2573DB 337BB 2552D 36/21P 28207B 2173DB 285T8B 2173DB 28W8DBA 28N03B 2505 238DB 439J936 3377DB 2181TB 82Z27B 28W23B 32ZP18P 42PW33P 32NW2DB 28ZH37B 32W8DB 32ZP38B 32NW7DB 32WIS 28N33B VTV1400 2987DB
536
Toshiba
2101TB 213T4B 2573DB 32ZP38
581
Toshiba
3377DB
216
Toshiba
2987DB
253
Toshiba
Toshiba
14T01B, 21TO1B, CT815, CT81500082B, CT824, CT832
746
Toshiba
TVD213B
726
Toshiba
CT90040
508
2987DB 3339DB 2877DB 322D09B 2173D6 14N21B2 14N21B2
063
536 063 271 098 117 232 530 581 130 473 088 182 064 216 253 508
Oct 05, 2011 | Toshiba 32WLT58 32 in. LCD Television
How do i connect my wii consol to my tv? I've connected all the cables correctly but nothing is showing on screen. My tv is a toshiba 37RV635D
1st ensure all the Cables are in the correct plug ie. input not output, as well as video or yellow in video, audio red and white in audio. 2nd make sure you set your TV to the input selection you used for your Wii setup. Hope this helps, Happy Gaming
Feb 24, 2011 | Televison & Video
I formatted my wii and it says must have a update from the shop channel if necessary, add wii points
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. Connecting to a Television Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom. Look for inputs marked Audio and Video IN. Do NOT connect your system to anything marked OUT. Don't see these inputs on your TV? Click here. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console. Insert the AC plug into a 120V AC wall outlet CAUTION: To prevent electric shock, match the wide blade of the plug to the wide slot and insert fully into the outlet. Plug the transformer into the wall outlet. The Sensor Bar can be placed either above or below your TV screen. Decide which option best fits you and click the image below for additional set up help, including mounting the Sensor Bar and proper alignment.
Jan 22, 2011 | Nintendo Wii Console
I am not sure i can get the dvd player to work or even how to play the wii on this tv
Hi
U can connect the wii on ur tv . connect the component video output of ur wii to the component video input of ur tv. normally component video connections need three RCA chord for video and one two RCA chord for audio input. component video will marked as Y,Pb, Pr.
ok
Dec 30, 2010 | Toshiba 27A33 27" TV
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
Dec 26, 2010 | Toshiba Televison & Video
I need to know what channel to operate my wii on. I have a toshiba tv that is about 8 years old.
Try changing the TV inputs to VIDEO or AUX, using the remote or a button on your TV. If there is not a way to connect the Wii to the TV using the 3-cable system (Yellow, Red and White), then you might have to use a VCR or DVD player to plug the 3 cables into and then transmit the audio and video from the Wii using the regular cable line of VCR or DVD Player on TV channels 3 or 4. If your Wii has a regular TV Cable jack on the back, connect that to the jack on the back of you TV and select channel 3 or 4.
Jan 05, 2010 | Nintendo Wii Console
Total Control Remote Code for Toshiba 28N33B TV
TRY ONE OF THESE CODES HOPE IT HELPS. - 018, 028, 083, 165, 205, 245,270, 279, 281, 370, 437, 446, 455, 456, 0R 471. IT WILL BE ONE OF THESE BUT UNSURE WHICH ONE IT IS SO TRY THEM ALL PAL. IF THAT FAILS BUT IT SHOULDENT TRY THIS DEFAULT CODE 042.GOOD LUCK
Jan 22, 2009 | Universal Remote Control NspireGear MP3...
Televison & Video Logo
2,411 people viewed this question
Top Televison & Video Experts
Electro Med Services...
