Question about Lowrance LMS 332c Mapping Sonar/GPS Receiver
I have a lowrance 522 igps and the unit has stopped rading the depth when I get into about 20 to 25 feet of water or deeper, this does this at any speed, the unit is alitle over a year old and has worked great up until about the last week
  • 1 more comment
  • eastwind63 Aug 12, 2008
    I think I fixed it, With the unit off, I held in the Page button and at the same time held the power up button until the not for navigation screen popped up, This was supposed to have reset(reboot) the unit. I now longer have the problem. Also they say that you can hold the zoom in and out together and the power up button, this will also help BUT you will lose your saved items including waypoints.
    I reboot the unit by holding in the page button and the power button together unitl the unit powered up to the not for nav, message, this reset it and it works fine now, can also hold the zoom in and out and power buttons together, youw may lose your way points.
  • FL_Crappie Mar 13, 2009
    I have a similar problem with my 332C and when I did the recommended fix nothing changed it continues to loose the debt. The screen will go from 0 to 500 feet then goes white with little small specks and on the right side of it will go up and down the debt scale. It just keeps doing that, then all of a sudden, it comes back on working fine for awhile. I thought it was just the transducer but when I put it on my old black and white unit, it works just fine.
    Problem Solver:
  • 10 Answers
I would verify that your "chart speed" is set to 100%.
Triton72
Posted on Mar 25, 2009
How can a lowrance 5300 globalmap iGPS be used as a fishfinder.
Sadly, the 5300 does not have fishfinder/depth capability.
If you require it, the link below is for the owners manual for your unit.
Sorry I couldn't have given you happier news.
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/GlobalMap5300ciGPS_0152-191_120506.pdf
Feb 24, 2015 | Lowrance Globalmap 5300c Igps 5" Screen...
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
What is the best set-up for ocean fishing between 40 to 100 feet using Elite 4.
go to set up in your unit set your depth to what you want min 40 feet max 100 feet
Oct 02, 2013 | Lowrance Boating
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
Loses the depth after around 60 feet.
Is the transducer face clean? Fouling and barnacles can cause poor depth readings. Also, a low power output from transmitter or poor sensitivity of the receiver (both internal), or a broken transducer cable connection (usually accompanied by heavy noise being painted on screen). With your ear in the water, fairly close to transducer (6-10 ft., you should hear a clear tick-tick-tick sound as it transmits on a medium depth range.. No power adjustment is available in the menus, but the unit does transmit at a slower rate, with wider (stronger) pulses on the deeper ranges.
Sep 14, 2009 | SI-TEX Sitex Cvs106lmkii Color Lcd With...
X510c most of the time it reads 1.6 for the depth, it flashes 1.6 then it will go to the correct depth for a shqrt time then get stuck on 1.6 again some times other depths but mostly 1.6
Does this occur at any depths...over 20ft even.
The X510c will have problems keeping depth in shallow water...especially if it is muddy, weedy down there.
If the problem occurs even in depth over 20ft, then try resetting the unit:
1. Turn unit off
2. Press and hold ZIN, ZOUT, and PWR until you see the depth (flashing or not) in the top left corner.
If the problem still occurs, make sure the transducer is clean and still mounted so that it is sending the signal straight down to the bottom.
If the problem still occurs, make sure the power is good. You can have the voltage displayed on the screen through the overlay data menu.
Does the problem occur at any speed? If the problem clears up when you stop or slow down, the problem is due to cavitation and the transducer will need to be moved to a location where it is in a smooth flow of water at all speeds.
If none of this helps, there may be a malfunction with the X510c. You can try to update it but you will need to get the software update from someone at Lowrance support and then find a way to connect your X510c to a Lowrance unit that has a memory card slot via a NMEA 2000 network. I can help you with this if you need.
Other than that you can have the X510c returned to the factory for service.
Jul 09, 2009 | Lowrance Boating
Lowrance x96 does not function after 20 feet depth
Your transducer needs to be adjusted so the return signal can be picked up. Some of these have to be super tuned to receive the signal. Also the transducer may be moving ever so slightly when the boat is traveling at speed. You may have some water turbulence interference all contibute to signal return.
May 26, 2009 | Lowrance X96 200khz Fishfinder
Loosing position on GPS
I hate to be the bearer of bad news, but it sounds like your internal module is on the fritz. I am pretty sure you can buy a external puck and a harness and it will work perfect. I did that with my hummingbird 997.
Apr 29, 2009 | Lowrance Lms 522c 5" Screen Color Internal...
Im trying to change my lowrance lcx depth from feet to meters
Press MENU MENU. Scroll down to SYSTEM SETUP. Press the rigth arrow. Scroll to UNITS OF MEASURE. Navigate to depth and select METERS.
Feb 23, 2009 | Lowrance LCX-27C GPS Receiver
GPS Logo
305 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
