Question about Air Cool AC436-GB Fan
I do not have the remote for the fan...
I am moving into a home with this fan, but there is no remote for it. I have looked and looked on the internet, but am having the hardest time locating a replacement
  • 1 more comment
  • karenmarie19 Aug 10, 2008
    Sorry - I guess I just assumed you would have all of the information in front of you like I do. There was a sticker on it and here is the information it lists:
    E7595 "YL" - I have found that this identifies Air Cool as the manufacturer.
    Model: AC-436 - Googling this usually brings up a white model, but the one in the house is pictured here as AC436-GB.
    Rating: 2.0 (Max.), 235W(Max.)
    Date:0505
    Vendor#11289
    UPC#792145350989
    SKU# 761512
    SN: 001438 Dg
    Ceiling Fan Made in China
    That's all I have. Can anyone help??
  • Anonymous Nov 17, 2008
    I have the same problem. I cannot find a replacemnt remote. I am getting ready to toss the fan in the garbage. Time to spend some money, but not on this brand again.
  • cierrabear Mar 08, 2009
    Got this fan made by Hunter Fan company from a woman that we put in floors for. I am ready to put up in new home, but it only works with a remote and she didn't give us one and can't find it on internet, even under the actual fan website. Does anyone know where I can get one? PLEASE!
We bought a home with 2 Hunter Fans with remotes. They both worked before we bought but after moving in noticed both did NOT work. I bought new batteries, but still do not work. Help
check breakers and switches --is their power to the fans the power to the fans has to be left on in order for the remotes to work
Aug 14, 2016 | Hunter Dryers
My grandson lost my remote to the 132cm. crosswinds ceiling fan. 0044687. where can i get a new one?
A new remote or new Grandson? For the remote you can try Lowes or Home Depot. They have a small display of handheld remotes for ceiling fans and remotes for overhead lights. I looked up the brand and Crosswinds is carried by Lowes.
I hope my solution is very helpful and that the remote will be reasonable priced. If you had an idea to add a fan to another room you could get the second fan and try its remote on the old fan. That way you would not be spending extra dollars for just a remote.
My mom was constantly losing TV remotes. Have your Grandson look under sofas and recliners as they tend to swallow remotes. If you have a cat, check your shoe closet because cats will place objects in their owners shoes. If you have a dog, it may have swallowed the remote. It might be worth checking.
Feb 24, 2011 | Heating & Cooling
We moved into a home where the remote is nowhere to be found. Where can we buy a remote?
Try contacting "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
Feb 17, 2011 | Hampton Bay 52 In. Northport II Fan, BN
Remote controlled ceiling fan has mind of it's own.
I have the same fan. The fan and the remote have some "jumpers" which allow you to change the codes, useful if someone else nearby has the same fan. You can see the jumpers inside the remote, open the back cover... you'll see "4 3 2 1" on the circuit board. Unfortunately you'll need to dismount the fan to change its jumpers, they need to be the same as the jumpers in your remote (which you can move around pretty easily).
Jul 01, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Hampton Bay Ceiling fan wobbling
The fan came with one or more clips and some small weights that easily stick to the blade. Now with the clip you put it in one of the blades, starting from the far end and coming inwards, little by little. Try putting the clip in the middle of the fan and turn on the fan and see if it continues wobbling, if it continues wobbling try moving it to left and right and every time turn on the fan and see what happens. When you find the correct spot, there you glue the small weight.
Apr 09, 2009 | Universal Remote Control Hampton Bay...
The replacement remote will work fine. All you have to watch out for is that the remote receiver and the remote transmitter are a matched set.
Jul 21, 2008 | Universal Remote Control Hampton Bay...
Hampton Bay Ceiling fan remote control
Hampton Bay is a Home Depot brand name. Most (not all) have a lifetime warranty. I think that if you take it to the nearest HOME DEPOT store, WITH the receipt they will help you by fixing or replacing the remote.
We have our home completely covered by HAMPTON BAY fans and one went out after several years and they replaced it no charge for another fan.
We have had great success with HOME DEPOT products and shop there often. Our preferred store is the one in Mesquite, TX on I635 East.
Feb 05, 2018 | Universal Remote Control Hampton Bay...
Concept II
Depending on what year the fan was made try looking very close at the actual body of the fan. you may find a small switch you can manually use to reverse the direction of the blades.. I may have some used working remotes that will work with your fan if you like please feel free to contact me at payitforwardx2 @ gmail . com .
Jun 08, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Air Cool AC436-GB Fan Logo
449 people viewed this question
Top Air Cool Dryers Experts
Are you an Air Cool Dryer Expert? Answer questions, earn points and help others
