Question about GE 46GW947 46" Rear Projection Television
GE 46GW945 46" Projection Color TV
Cannot seem to progam cable channels not using a cable box but it will only find up to channel 60
Over the air channels 60 or above will all be gone soon. The space will be allocated to cell phones and such.
This may be what you are seeing.
Posted on Sep 10, 2008
Projection TV. DVD works. Cable often seems, "untuned". Static & un-fine-tuned sound of channel with black screen. Then, later, it will come on just fine. Sometimes, will go back to untuned status.
I would suspect your cable box first. I would unplug the power cable from your cable box and wait 60 seconds. Plug it back in and try to watch cable tv. I would also make sure the coaxial cable going from the wall to your cable box is connected properly. I would also make sure the cable going from the cable box to the tv is connected properly. Test your tv and see if it works correctly when you watch cable. If this fixes the issue you are good to go.
  • If this makes no difference use a set of new cables if you have them.
  • If this does not work then call your cable company. They may have to replace your cable box.
May 25, 2015 | Televison & Video
Why all my cables channels not working
if you are using coax cable to conn cable box to tv, be sure to use the analog ant conn on back of tv, and there is a switch on the back of the tv for selecting channel 3 or 4, for cable box use. be sure to turn tv to the same channel the switch is selected to, and always use the cable box to change channels/ programs, not the tv channel selector.
Feb 26, 2013 | RCA R52WM24 52" HDTV Projection Television
Some of my channels are only in spanish, some have no sound
Look first in the menu for the set and then in the menu for a box if used:
In either place if set is set to SAP (secondary audio program) some channels will be in Spanish or have no sound.
It can be the setting in the TV or a cable or sat box if used.
Oct 23, 2012 | Mitsubishi VS-60111 60" Rear Projection...
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
Screen is black and won't pull up dish network
not sure on what dish system in use - but if you are running a sky box or freeview the box will reset it self when turned off-
if so do away with ch.60 and fit av(scrat) lead to back of tv. & box.and progames will autom. come up on av channel.if this dose'nt work drop me an e-mail with more detail of your system and I'll try again.
Aug 07, 2009 | Televison & Video
Lost some stations on my Sony lcd TV.
It is a possibility if you are using a cable tv service, without a converter box, that the cable company has limited the number of station you are able to receive. It seems to be their new ploy to get subscribers to get a box since the digital changeover. I also may be that the TV's tuner memory may have to be re-programmed. Go into the menu and go through the channel scan process and see if they return. If they don'y it may be a tuner issue. An easy fix is to get a cable box!
Hope this has been helpful
Jul 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony 60in Grand Wega Channel Guide comes up/Screen goes Blank
u may have a bad cable box ( drectv) try a dvd player on the tv if it work fine that means u have a bad cable box ( drectv)
May 08, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
DTA800B1 how or should I say why can I not see channels on the VCR when the converter is hooked up to it and the tv works just fine but will not set the channels on the vcr
instead of putting the converter box on ch4 ,put it on ch3 same as the vcr . set the converter box channel for the channel to be recorded, program the vcr to channel 3 for the channel to be recored. set the time and date on the vcr does not need to be on for the program to be recored but the converter box needs to be on.
Aug 21, 2008 | RCA Televison & Video
GE 6OGW947 60 in Rear Projection T.V.
it is your provider not the tv, i had the same problem. they just seem to lazy to fhelp you.
May 23, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Colors Off with High Def Comcast Cable
check your cable connections between tv and box, especially the red connector, try unplugging and plugging back in the cables.
Jul 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
GE 46GW947 46" Rear Projection Television Logo
74 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
