Question about Philips Magnavox 51MP392H Rear Projection Television
Intermitant Convergence Problem
"Bowing" and distorted picture. Looks like a really bad 3-d picture. Sometimes it lasts longer but for now it eventually goes away either after the set has been on for a while or been turned off and on a few times. When it is in this "funky" mode, I can not adjust the manual convergence. When it clears, the convergence appears to be perfect.
I've seen several posts about the ICs needing to be re-soldered or the power supply needing to be replaced. I am not an electronics wiz (nor do I have access to any solder equipment). I paid less than $1000 five years ago for the 51" Magnavox...just wondering if it's better off to replace rather than spending what I imagine will be several hundred $$. i have like ghost or shadows on my screen i try to fix whit the control but din't work
  • indy80 Aug 10, 2008
    not realy
  • 1,031 Answers
Seems it s a convergence problem and you cant do the repairs go to the link
http://servicemanuals.vstore.ca/ they repair and give you 6 months guaranty but it will cost you around $500 except for SSB circuit card so you can weigh the cost against buying new one
Posted on Aug 10, 2008
    Genius:
  • 1,011 Answers
Dear sir/madam,
The Convergence board inside your televison.
maybe there's a loose connection in it. Remove the board for inspection and check the IC solder joints and any other cold looking solder.
thanks
good luck
    Genius:
  • 2,920 Answers
Thereis a convergance board in the front of the t.v. where a tech would ajust it. but if you have shadows and bows than a tech willl charge you anywhere from 55 dollars just to look at the t.v up to 300 dollars if he has to replace the main convergance board up front not counting any of the fine tuning.... if i ere you i would just buy a new one. it would be cheaper.
    Genius:
  • 1,847 Answers
My option will be to replace it. or spend couple of 100$ and get it fixed
  • Legin Varghese
    Legin Varghese Aug 10, 2008
    This sounds like a convergence problem. it is a common problem. there
    is a adjustment in your menu for this. it might be called projector
    setup on your model. if this does not do it then you need a repair. a
    cost will range around 400.00.
    good luck :)
Problem with Sony KP46WT500: Each line on the
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | Sony KP-46WT500 46" Rear Projection...
Bowing convergence lines , projection tv
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Feb 04, 2010 | Mitsubishi VS-80803 TV
Bowing of picture at top and bottom towards center.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Zenith R57W46 bottom bowing and color off and double lettering
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
SPEED BUMP OR BOWING
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking. Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com for a kits.  Just make sure you replace both of the convergence chips and all of the convergence resistors.
Aug 25, 2008 | Philips 60PP9202 60" Rear Projection...
if you cant do the repairs yourself you can go to the link i give you leave an e-mail they repair the convergence circuits and guarentee them for 6 mos
Apr 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
I am thoroughly confused now
yes the convergence iCs will give you a severe picture distortion bowing in either from the top bottom or sides.as well as the 3-D look
Mar 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Bowing at bottom
convergence ic bad, should also replace bad caps in DM
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
· http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
