Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t code problem
At random parts of any cycle (but mosly spin). the wassher will stop and flash " H F" code and i havent found a meaning to that code yet.
  • goose2000 Aug 28, 2008
    my kenmore elite he3 keeps flashing: H - F, during various cycles. What does that mean?
    New Friend:
  • 88 Answers
Check your water supply make sure that you have both hot and cold water on at all times. Pull the hoses off and see if the screens on the water valve in the back is clogged.
Posted on Jan 13, 2009
Have a Kenmore Elite HE3T washer. Put appropriate detergent, fabric softener in, selected NORMAL cycle, spin speed, etc. Just sits there. Pressed START button several times. Nothing. Little cycle lights...
I own a 18-year-old Kenmore front-load washer so I'm not sure this will apply, but here goes... My washer requires me to press and HOLD the start button for a few seconds before it will start. At that point the door will lock and the washer goes through its startup phase. I think that is a "safety feature' to keep from accidentally bumping the button and starting the washer. See if that help. Good luck!
Nov 22, 2017 | Kenmore HE3T Washer
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
''SUD'' Code on Kenmore Elite HE3t after new pump.
Run some white vinegar through a rinse cycle to get the excess soap flushed out.
Sep 17, 2009 | Washing Machines
Kenmore elite make a funny sound during a drain spin cycle
it either is the something in the pump or something in between the inner tub and outer tub
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
What causes the HE3t washer to stop in spin and rinse cycle?
Sometimes the unplugging helps, or hitting "Cancel" several times.  Guaranteed to work though is to remove top, reach down the top to the door lock.  (Tight squeeze and need to be a little tall to reach) Once your hand is down there, on bottom of lock mechanism is a small handle that must be pulled straight down and manually unlock the door.  This can also be accomplished by removing lower front panel and reaching up to do the same.   BTW, while in the top, make sure all the electrical connections are tight.  I found some loose before, probably from the spinning action.
Dec 06, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite he3T front load, bought 2004
I'm going from memory on the "H F" code: If it stops during a filling cycle, it's probably the small rubber hose running between the pressure switch and the bottom of the tub. Mine had a small hole rubbed in it as a result of it rubbing on the counterweight on the back of the tub assembly. I replaced the hose with some vacuum hose I purchase at a car parts store that had the same inner diameter. I also made sure the hose wasn't rubbing the counter weight when I reinstalled it.
Jan 02, 2008 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
145 people viewed this question
Sal De
 Brian Main
Brian Main
