Question about Dishwashers
Miele G8481 dishwasher stopped running - "intake/drain" light came on
    Genius:
  • 1,847 Answers
Check the drain and the water inlet.
Posted on Aug 10, 2008
  • Legin Varghese
    Legin Varghese Aug 10, 2008
    Intake/Drain fault indicator
    This is essentially to alert you that the Waterproof system has
    activated, though it can also simply mean that the filter is blocked.
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Miele dishwasher 892 intake/drain light blinking
The intake light blinking error can be caused by several different problems and may take some pains taking effort to figure it out. There is some helpful information about Intake/Drain light flashing. http://www.techanswerslive.com/appliances/miele-icognito-dishwasher-service-mode-error-codes/12
Apr 18, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Sep 08, 2009 | Miele G892SC SS Dishwasher
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
I had a similar problem with a different Miele. I found that under the door, there is a removable trim panel (may not be one on yours). Under the trim panel was an acoustically sealed metal plate held by a couple of screws. i switched off and disconnected the electrity, then removed the plate. The bottom tray was filled with a big puddle. I cleaned that up and put the machine back together and it ran fine. Accordingly, I'm getting some replacement shaft seals for the thing as it looks like its worth fixing. Good luck with yours. rupertvdP
May 31, 2009 | Miele 23 in. Novotronic G841 Built-In...
Miele intake light on since new sink,disposal installed
check and see if the disposer drain port plug was removed. intake/drain light means slow drain or no drain
Feb 04, 2009 | Miele Touchtronic G892 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Dishwasher not running
just got this, and have same prob, i have run through all checks
Aug 26, 2006 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
113 people viewed this question
Top Dishwashers Experts
