Question about Peavey 32fx USB 32 Channel Mixer
Peavey 1600D Powered mixer
We have just acquired a Peavey 1600D Powered mixer to use for a weekly jam we have using most of the 16 channels. We have a manuel for it, but
can you give us a short course in its operation, as we know nothing about it's operation.....
We are mainly using the 1/4 mic jacks and that is all.
  • 5603 Answers
SOURCE: i have just bought a peavey xr800f powered mixer
There are SEVERAL things to set. First is setting the EFX mix for those channels you want the effects to be active. Next, select the effect you want AND the TIME for the effect and FINALLY the amount of the effect output to go to the MAIN and MONITOR outputs. Also the effect disable button below the effects needs to be in the correct state. ALL of these have to be set for using the effects on the mics.
Posted on Feb 07, 2011
soundchasr
  • 8 Answers
SOURCE: Peavey sound board 2 channels not working
check for cold solder joints from the input jacks and the fader. If any look suspicious (dull or grainy) re-solder.
Posted on May 29, 2009
  • 5603 Answers
SOURCE: Hi, I have a Peavey XR 1600D Power Mixer That has
It is a pain... After opening the unit you will probably have to remove a lot of the knobs and jack hardware and a few screws to allow moving the board away from the face to get to the sliders.
PLEASE NOTE that often the sliders have many leads and getting ALL the solder removed so that part can be lifted out. I use a special desoldering tool that uses a vacuum source. If one doesn't quite get all the solder and forces the part out, you can lift circuit traces... USUALLY solder wick does NOT work adequately to remove the solder.
HINT: Wiggle each lead to make sure it is free of solder to the board before prying slider out.
Posted on Dec 02, 2010
  • 5603 Answers
SOURCE: I have a peavey 8600 powered mixer. If i run
If you run the speakers FROM the main you should have BOTH the effects and the EQ invilved with your signal.
Posted on Apr 20, 2011
bobhifi
  • 635 Answers
SOURCE: Useing a Peavey XR 800F
First of all confirm if the speaker impedance is not lower then the recommended Ohms at the back of the Mixer speaker socket.You can use an 8 Ohms speaker on a 4 Ohms amplifier but not vise versa .
Next see if the fan on the mixer works. If not the Amp is getting very hot and this will lead to unwanted distortion. You can confirm if its a heat related issue by playing the mixer at low volumes for more than an hour and see if it distorts.
Posted on Apr 26, 2011
I want to use theMackie as a sub mixer into a powered "all in one" Peavy mixer, where do I come out of the Mackie into one of my powered mixer line inputs?
Take the main outputs into a stereo input (or a pair of mono inputs) on the Peavey - without knowing which Peavey I cannot tell you further info re set-up but as you'll be sending line level signal you'll need to back off the gain on the channels you input to on the Peavey
Nov 17, 2016 | Mackie Music
I have a Peavey amp but no sound is coming out?
Bad output transistors or bad Soldier joint in output section
Nov 26, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
Apr 30, 2011 | Peavey Electronics Peavey 00512140 PV 14...
I have a peavey 8600 powered mixer. If i run powered speakers through the main output on the front will I not have effects?
Apr 20, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Mar 08, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Can I connect this mixer to a main mixer with 17 channels that is connected to an amplifier?
Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output,  or monitor  send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
Feb 10, 2011 | Peavey XR 8600D Class D Powered Mixer
Hi, I have a Peavey XR 1600D Power Mixer That has 3 sliders that need replacing because they have snapped. I have the new sliders but need to know how difficult to replace. Thank You
Dec 02, 2010 | Peavey XR 8600D Class D Powered Mixer
How do i connect 2 monitors to the one monitor output jack on the peavey xr 600c mixer..cheers My product not quite the one as listed from your product database but may be similar
The monitors will have to be POWERED monitors with built in amps.
You can simply use a wye splitter cable to drive the two monitors. Run the cable from the mixer to one monitor and put a wye cable and an extention to the second powered monitor speaker.
Jul 25, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey 32fx USB 32 Channel Mixer Logo
174 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
