Question about Lexmark Office Equipment & Supplies
Lexmark x9350 printer. "Check inside the printer for obstructions..." There is a white ribbon, seems ok. Also a rigid gray/black line that seems ok. But there is a fine line also attached to the print cartridges that just floats loosely, unattached to anything but the cartridges. I've checked everywhere and cannot find an obstruction, When I pull a cable the cartridges slide easily. Anything else I can do?
    Master:
  • 726 Answers
Take out the cartridges turn off power, turn it upside down and shake it gently and look inside proper see if there is any thing at all put the cartridges in and turn on see how you go with that ,,,,,,,,,chris
Posted on Sep 18, 2008
    Sergeant:
    Champion:
  • 214 Answers
Clean the carriage rod and restart the printer and try
Posted on Sep 09, 2008
  • Lexmark Master
  • 19,396 Answers
The ribbon it is probably the encoder strip, don't touch it. Try gently moving the ink carriage back and forward on the rail.
Turn printer upsid down and shake it a bit, see if there is any lose screw coming out from inside.
    President:
  • 1,257 Answers
Go through this pdf file to solve the issue and please reply to us if you are getting any error code.
http://www.kproxy.com/servlet/redirect.srv/sruj/shovovvgukkgih/stuv/p1/downloads/4039ErrorCodes.pdf
Posted on Aug 10, 2008
    Genius:
  • 2,920 Answers
What exactly is the printer doing or not doing?
X9350 loose belt
This printer has opposite side belt driver gear please adjust this gear
Apr 24, 2013 | Office Equipment & Supplies
My Lexmark Pro901 will only print black and white
Possibly there is check on print in gray scale
go to properties of printer then printing preferences and check for print in gray scale option and uncheck that box and then again
Jul 18, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
My Lexmark X9350 "can't associate with wireless
Even though the printer says it supports WPA encryption, it does not. It will work if configured for the far less secure WEP.
This is the only answer that I have, unfortunately. The X9350 is a terrible machine.
Dec 09, 2010 | Lexmark X9350 All-In-One InkJet Printer
Lexmark x9350 has horisontal lines and gaps
horizontal lines mean that there are inks overflowing on the print head and has some ink on a part of the printer where the paper is coming out while gaps are clogged heads. You may need to clean the print heads. I suggest to go to your local store and get kleenex with some distilled water and wipe the head area to take the lines out. for the gaps, just do a standard cleaning of printer heads using the software provided with your printer.
Jun 19, 2010 | Lexmark X9350 All-In-One InkJet Printer
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
Check inside for printer obstruction . how do I open the case ?
You do not need to open the case…what they meant that you may have paper jam and that get accessed from the front paper feeder or from un correct instillation of the inks and that by opening the door in front and replacing the ink again in the housing and closing the door good , let you know. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future.
Sep 26, 2009 | Lexmark X9350 All-In-One InkJet Printer
Lexmark x9350 printer problem
this is the result of a lose belt or dislodged spring, tightening the belt.
There is not much you can do, you can attempt to open the printer up and tighten the belt, however, it would be easier to buy a new printer.
Jul 21, 2009 | Lexmark X9350 All-In-One InkJet Printer
Initial set up for fax.
Turns out I'd never had a problem in the first place. Lexmark - predictably - had people like me in mind when they designed there milti function printers particularly the X9350 Series. All I ever had to do was plug in a phone line into the correct port on the back of the prntr and the set-up software that I installed when I bought it does all the rest. It's terrific! The printer's software automatically found and configured my laptop and activated the fax function in the productivity suite the comes with the printer. There seem to be a lot of smart people at Lexmark. They've impressed the hell out of me.
Sep 26, 2008 | Lexmark X9350 All-In-One InkJet Printer
My lexmark x75 only print black and white
Please check color cartridge is ok or not
if it is ok then check your printer configuration in Your pc it should be a gray scale printing ....
May 23, 2008 | Lexmark X75 All-In-One InkJet Printer
Photo ink cartridge isn t recognized
Look in your printer manual or the pc manual for it and check to see if the 40 cartridge is actually compatable with your printer. You may have bought the wrong one. I would complain about the lexmark store to the main lexmark company because not only is that pure ignorance, they have a resposibility to sell the correct gear to customers, and to satisfy consumer rights. Always make sure the cartridges are the right ones first as once open many stores give you hell over replacement even with docket. Keep all dockets until next replacement (i stick mine to side of printer!) If it is the right cartridge, you may have a dud, in which case the store has to take it back, demand it!, or you may have to clean your heads with printer program or manually with solution and cotton buds (q-tips)
Aug 12, 2007 | Lexmark X9350 All-In-One InkJet Printer
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
