Question about Fuji FinePix S7000 Digital Camera
Trouble with outdoor photos with my camera (indoors seems to work great)
I have owned the s7000 for years without trouble. Its been a great camera. Recently it started OVER EXPOSEING all the outdoor photos that I take. Just the outdoor photos. The indoor pictures seem to be OK. Maybe it is a "shutter" or "Fstop" issue? The camera just started doing this on its own. It was not dropped. I tried resetting it, that did not fix the problem. NOTE: the display shows the F stop and shutter speed in the "auto setting" but I wonder if it is not correct it for some reason..MY thinking "it may be stuck on one F stop or some thing. Thats my guess. Thanks for your time.
I have a FinePix S7000, I can't read to the computer, but I can to the camera. I tried every thing nothing, the computer saying there is not picture on the card, I change the card still same result. Need help...
Posted on Jan 06, 2009
  • 21 Answers
Hi. please check the ISO setting. It might have been changed. let me know, I have the same camera, will check more on it for you. good luck.
Posted on Dec 26, 2008
My outdoor shots always seem washed out with blueish tones. How do I fix this?
Appears that the f stop on your camera is not working properly with the result that your outdoor shots are overexposed. Could be the f stop motor, the photo cell reading lite level, etc. Definitely a job for a pro.
Might cost a fortune to repair so might be advisable to cut losses and get new camera since parts and labor on those devices are costly.
Oct 31, 2015 | Cameras
I have a Samsung SL420 camera. Outdoor photos are great. Indoor photos colors always have a gold hew to them. What am I doing wrong. I always use the auto setting for both indoor & outdoor p
You will need to adjust the "white balance". Your camera may be able to do this by pointing it at a gray surface, and setting something. I don't have your camera instructions, but it's a normal adjustment for indoors.
Sep 11, 2014 | Samsung SL420 Digital Camera
Yashica ez digital 6032- 6 mp camera.. i got one sparingly used yashica camera... with above spec... which shows trouble when taking stil pictures outdoors... indoor pictures and video indoors n outdoors...
i am using yashica ez digital 6032 camera but while using SD card of 4GB memory, it is not working. it is asking to format. Pl. help me regarding this problem. Shall i format the camera?
Apr 27, 2010 | Cameras
Blurry indoor photos
blurry pictures often comes from the slightest movement when the pictures is snapped.
Don;t know if that is your problem or not try a photo tripod and see if that helps or check your trouble shooting area of your amnual. if you don't have the manual go to this site for any type of manual::::
Aug 28, 2009 | Cameras
Blurry indoor results- using flash
Built in flash units on digital cameras are only meant to be used out to a distance of 6-12 feet. When taking photos of events ie graduations, sporting events, concerts you need to do two things. 1). Change the ISO setting on your camera. This is the same as the old film speed ratings the higher the number the more sensitive the camera becomes. try ISO 1600 or above in low light. 2) You have a mode setting, set it for the type of lighting that is in the space you are in, incandescent, flourescent or whatever, it's easy to do. and finally 3) Turn off your flash! When your flash is on your camera closes up the aperature and takes the picture at a higher rate of speed in anticipation of reflected light off of nearby objects, so your pictures will be darker and blurrier with the flash on.
Even high grade professional flashes only work out to 20-30 feet so they won't help you. Read your cameras manual on taking pictures in low light conditions. It will give you all of the above in great detail. You have a great camera but you need to learn how it works, don't give up on it.
Jun 02, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
this problem may happen due to sticky shutters. when a camera is left non operative for a long time sometimes the the shutter gets stuck due to some sticks substance between the blades. BUT you specified thet it's not taking OUTDOOR PICTURES that means that it is working fine indoors ??? That's confusing..
Feb 26, 2008 | Fuji FinePix F10 Digital Camera
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Dec 26, 2007 | Nikon D70s Digital Camera
Pictures overexposed in daylight, visible lines in photos
1. Adjust ISO or ASA 100
2. Adjust AWB Indoor florescent or Bulb while outdoor select sunny or foggy it depends of the place
Dec 25, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Casio Exilim s500--horizontal lines in picture and autofocus creates blurry pics
It appears this problem is due a failing CCD device in many brand cameras. All the manufactures use the same source(s). I have not persued Casio as yet, but other companies are offering a recall to replace the CCD for free. I plan to use this approach with Casio. Search the web for "failing CCD in digital camera", it describes exactly what we are observing.
Dec 02, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
50 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
