Question about Thermador SGS36GS Gas Cooktop
Extra low burner that won't ignite
From your explanation of my non-igniting cook-top burner it may very well be the potentior. Would that explain why there is no evidence/smell of gas when it is turned on? What is the potentior and where is it to fix/unclog, or change it? Thanks...
  • Anonymous Sep 24, 2008
    ignighter on low burner was clicking constantly and eventually both low burners went out. We now get no ignition nor any gas in those to burners. What to do?
  • 3 Answers
Solution is a lot simpler. Please click on this link http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/20666-no-gas-xlo-burners.html#post62329
Posted on Mar 26, 2009
  • 4 more comments
  • xlogas Mar 26, 2009
  • xlogas Mar 27, 2009
    Sorry for the confusion. The real (working) link is this.
  • xlogas Dec 31, 2013
    http://appliantology.org/topic/13139-the...
    OOPS I've forgotten to add a comment .. On THIS LINK
    grrr #$%% When I used FIXYA for the last time 4 years ago, I was able to use a little bit better online editor. What I am using right now to write the addendum to my previous comments IS PURE NONSENSE. OK ??? But I am still trying to help people. So... the two original links (4 years old) are not the best. If you really want to fix your THERMADOR cheap, then, please, click (or CUT&PASTE) this URL to your browser http://appliantology.org/topic/13139-the... . The solution really works and it is very economical.
    THIS is the SOLUTION which works http://appliantology.org/topic/13139-the...
    Novelist:
  • 130 Answers
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
Posted on Aug 10, 2008
SOURCE:
Gas burner won't light unless gas is turned down to the low position.
I've had this happen before,first make sure that the black burner cap is clean underneath and it's making good contact with the aluminium burner,also make sure the igniter is sparking across to the burner, check the ceramic coating around the igniter isn't cracked or the wires shorting out . Good luck.
Feb 20, 2014 | Jenn-Air Cooktops
Clicking of igniters continues non-stop unless I unplug the cook top.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Sep 25, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Gas cook top
thanks for the question yes some stoves do this and its normal when the burner you selected lights turn to low or hi the igniter will stop they do this to save on igniter modules thanks the appliance doc
Sep 16, 2008 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Thermadore cooktop SGCS365RS
if its one of the center burners witch has the auto on off for extra low its the moduel under the handle
Potentiometer
Jul 19, 2008 | Thermador SGS36GS Gas Cooktop
Thermador SGS36GS Gas Cooktop Logo
999 people viewed this question
Top Thermador Cooktops Experts
Spencer Field
Spencer Field
Level 1 Expert
Eric Gundersen
Level 1 Expert
Archie Ferrarini
Archie Ferrarini
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
