Question about HP Computers & Internet
I have an HP pavillion elite model m9250f. when I turn it on, the 19 inch monitor will show a screen that says no dvi input and then show a screen saying that the monitor is going to sleep.
    Scholar:
  • 65 Answers
Have you checked the plugin in the back of the tower. check that all the prongs are their and attached. thier could be a number of things wrong. 1). could be the monitor itself, try it on a diffrent system. then we know if it's the monitor or the video card. 2). try hooking up a diffrent monitor to you tower and see if it will work that way, if not then you'll need to replace your video card. 3). check your drivers, kinda hard to do with no screen i know.
Posted on Aug 10, 2008
Hp elite 7100 dvi no signal
If your monitor has both VGA and DVI video inputs and does not auto-detect the video inputs then you need to go into the monitor's Menu and select the DVI video input.
Mar 28, 2013 | Computers & Internet
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
I cannot seem to connect my new Asus VE247H 23.6 Inch Monitor with my New HP Pavilion Elite 460a Computer
Click here to see your screen specifications.
Your screen Supports DVI, HDMI 1.3 and VGA inputs.
Your Computer should have at least one of these connectors. The cables should have come with the screen.
Match them up, I would use either HDMI or DVI as these are digital signals.
VGA is analog, but if you can only use this one then go for it.
I do not see a reason to purchase an adapter.
Simply plug in at the wall and into the Graphics card of your computer.
You might have a card or onboard Graphics.
Thumbs up!
Let me know how it goes!
damnor01
Jan 20, 2011 | ASUS LCD Monitor
HP w1907 both DVI and VGA inputs are active
hi mate, its seems by what your saying that you have both dvi and vga cables connected to the monitor from the computer, the easiest solution is to remove the unwanted input cable from the pc and monitor ( i would remove the VGA) then restart the computer you really should only run a single cable either vga or dvi not both at once the monitor just comes with both cables encase your pc doesn't have one of the connector types, there not there to both be connected at once :)
if you have a reasonto want to keep both cables connected then you need to right click your desktop , click display settings, you should see two monitors there labeled 1 and 2
click on the phantom display ( probably number 2) then click the drop down box titled "Multiple Displays" and change the option to "disconnect this display" , then apply the changes and then your problem is solved
if you are useing a older windows like 7 or 8 the proceedure is the same but the name of the drop down box may be diffrent but it still has the same option to disable the display
below is the windows screen ( i have 3 displays so ignore number 3)
Apr 19, 2017 | HP w1907 LCD Monitor
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
New HP PC won't show up on monitor
So the problem there is your VGA adapter. Try installing a Graphics card in your motherboard. Check the type of graphics card slot whether it is a VGA or PCI Express slot. Hope this helps.
*Your vote is highly appreciated. Thanks in advance.
Best regards
Dec 26, 2008 | HP Computers & Internet
No DVi input, then computer goes to sleep
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
Detech Input message on the screen at the starting
I have the same monitor and assume you have both analog and digital inputs. In other words, both a DVI and standard analog monitor input. I noticed on mine that there was a "factory reset" on the menu. Have you tried that? What type of video card are you connecting to? DVI? Do you have any adapters or gender changers connected to it?
Let me know.
Jason
Dec 04, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
MONITOR WONT STAY IN DVI MODE
Did you try the card in your friends machine? That would be the next step. The card could be going bad.
Feb 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Computers & Internet Logo
103 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
