Question about Garmin GPS
My Garmin Foretrex 201 with the rechargable Lithium battery has trouble accepting a charge. When it does, the Menu screens are locked to the boot screen and the satelite screen and it will not toggle thru menu's. What can be done here to reset, load new software, drivers etc. Kevin O'Dougherty
3 Suggested Answers
  • 638 Answers
SOURCE: My Garmin Foretrex has a
You can download tracks and waypoints via EasyGPS for free, or ExpertGPS or Garmin Mapsource. These programmes will transfer waypoints, tracks and routes to your PC.
If this solves your situation, please come back and rate our solution. Thankyou.
Posted on Jan 08, 2009
  • 1082 Answers
SOURCE: I have a Garmin GPSmap
Check the charger for correct output voltage. If its good then its a defective battery.. Replace it.
Posted on May 05, 2011
How to check if the USB port is damaged ?
If you are able to connect to your computer using the USB port, then I would check your "New" batteries.
Apr 03, 2016 | Garmin Foretrex 301 Handheld GPS Receiver
Garmin foretrex 301 will not power up
Replace it. I think the battery is dead and unless you are up for cracking open the case it is done done for... You can always try a mast rest first though... Just google that one.
Apr 21, 2014 | Garmin Foretrex 301 Handheld GPS Receiver
The battery on my 201 forerunner is only lasting 5-6 hrs, how do I change batteries and is it worth it. Cheers Tom
It is actually meant to last for 15 hour per charge, and it lasting just 5-6 hours simply means it is either not fully charged or the battery is weak.
It uses a lithium ion rechargeable battery, and it can be replaced, you will have to open it up to be able to locate the battery.
If you are not familiar with such activities, i will strongly advice you get a repairman replace the battery for you.
Since taking a walk with it wont take up to 5-6 hours, it will be best you leave it that way, and try to recharge as soon as it drops, but if you use it for over that amount of time in a day then you can replace it. the battery is located right underneath the wrist band used in strapping the hand.
Take care
Oct 12, 2010 | Garmin Forerunner 201 GPS Receiver
I am trying to connect my pc to a garmin foretex 201 vis usb and cant get the interface to work
This happened to me alswo. I had to go to the Garmin site and update my software. If you aren't sure how to do this, I advise getting assistance from a Garmin Tech.
Dec 14, 2009 | Garmin Foretrex 201 GPS Receiver
Water inside Garmin, so no display.
This was recommended by Coopers4508 under the Forerunner 201 thread, and it worked equally well for my Foretrex 101.
As Coops said:
I know it sounds crazy, but worked without damage. Placed the forerunner in a table vice (long end to end) and gently applied pressure, opened right up.
It worked perfect for me - just be sure to compress slowly and listen for the separation of the centre seam. A very tidy solution.
Feb 09, 2009 | Garmin Foretrex 101 GPS Receiver
Garmin forerunner
Nov 21, 2007 | Garmin Foretrex 101 GPS Receiver
Changing a Foretrax201 Battery
Hi. Did you solve this problem? I have the same issue. Cheers rogerlaidlow@hotmail.com
Oct 06, 2006 | Garmin Foretrex 201 GPS Receiver
GPS Logo
99 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
