Dead-no power-son spilled drink......
Thanks for the suggestions you previously posted...one more question-
is there a main fuse on the mother board? i was able to completely dissamble the hp530,but, the only thing i could figure out was the the button battery was bad [ only .6 volts] so i replaced it----no help.
thanks again for the response !
    Sergeant:
  • 395 Answers
Hi
Yes, they usually is one but it mat be on a separate power board
Posted on Aug 10, 2008
SONY LED TV MODEL - KDL-40W900A .MOTHER BOARD IS DAMAGED. REPLACEMENT COST 8000-10000 INR. CAN ANY ONE SUGGEST IF REPAIRING MOTHER BOARD IS POSSIBLE?? AND WHERE IN MUMBAI ?ANY CONTACT DETAILS ...
Mother board repairing at component level is not possible to Sony. It is best to replace it. Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 02, 2016 | Sony Televison & Video
HP G61 no power
open *********** board battery some time or " mother board battery
inside 3pin jumper switch. open this jumper middle pin to other pin connect some time 1 minute & jumper set previous position.
or" see mother board battery
inside reset switch
May 28, 2012 | HEWLETT-PACKARD G61-306NR Notebook
Tech says i need new motherboard computer won´t turn on
Before you buy a new mother board, (the L300D-13S board is around $185 from China), remove your battery, leave it for about 5 minutes. Use only the Mains power supply and see if it will switch on.
Fit the battery, plug in the Mains Charger and see if the battery charge light comes on. If it does and it won't give you a screen or flash the hard drive light or power up the hard drive, then I am inclined to go along with a replacement Mother Board.
The laptop has to complete the POST and if it doesn't that usually points to Mother Board problems.
Were you trying to upload a newer version of the BIOS before it failed?
Good luck but check ebay and beware there are some really dodgy frauds out there.
Oct 20, 2010 | Toshiba Satellite M35X-S1142...
I have this motherboard and it won't post. The HD light stays on but does not appear to be spinning. I swapped HD's...same problem. I think the MB is bad. Any suggestions on what to check next?
If the mother board will not complete the POST, (Power On Self Test) changing the drive will have no effect. You might want to remove all memory and check again ... your memory could be causing the problem. Remove all boards and attachments except mouse, keys and monitor of course so you can see what is going on.
If it will not POST, get another board.
Basics ... always go back to basics.
Thanks for your interest in FixYa.com
May 31, 2010 | Intel D865GBF Motherboard
Flashing green light on psu
you need a new power supply and try it see if any change it try to take off your modem and one of the 2 will be a problem thanks
Nov 08, 2009 | Computers & Internet
This was posted previously. M15i does not turn
in following order, either and most likely the Power supply is bad, That is located under the cover where the paper comes out, On the left side of the machine, where the on off switch is, there are 2 screws that hold the cover on, the power supply is there..A fuse on it may be bad, but that power supply fails due to heat.
Next is the main board failure, but that is less likely , about a 10 percent chance. The power supply print board crack from heat, and the filter capacitors also fail.
Feb 24, 2009 | Xerox WorkCentre M15i Laser Printer
Where to located Boards
Ryo,
I would suggest you send your boards or the complete chassis to a company called PTS Electronics.
They will do a complete test of the boards and replace the defective components.
Sep 04, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
COnvergence issue
What board did you replace when you say main board. was it the board with the flyback on it? Let me know and also verify if your model number is the PCN5425R and let me know exactly what happens when you try to run perfect focus. Please respond to this post so I can have access to previous posted info. thanks
Jun 19, 2008 | Samsung PCN5425R 54" Rear Projection...
Power
Hi Harold L
Yes it is most probably the fuse that has gone.
Take of the top cover of the Projector and look on the Main Powersupply Board ( the one with the AC inlet on it ) - you'll see a fuse on the board.
Change the fuse even if you cannot see any markings or discolouration on it.
Good luck and I hope this is of help.
If this doesn't work - just post another posting and I'll respond ASAP.
Thanks for using Fixya !
Apr 23, 2008 | ASK Proxima C160 Multimedia Projector
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
