Question about JVC MX-GT88 CD Shelf System
Other uses can u use the speakers in a car?
  • calle1113 Aug 10, 2008
    can u use the speakers on a car
    Problem Solver:
  • 3 Answers
Lol yes you can i have the reciever hooked up to a 300W inverter and the speakers behind the seats in my truck and it sounds amazing though it is kind of a "ghetto" thing but it works and sounds amazing just hook the speaker wire into the back of the reciever start your car plug the inverter in and enjoy... theres a catch though if it happens to turn off randomly its not the receiver you might just have it too loud. my advice is to buy an inverter with an external fuse on it so you dont blow the fuse in your car. the inverter i have has a warning beeper on to tell me that i am using more power than it can handle so i just simply turn the volume down on the reciever but if it turns off i just unplug the inverter and plug back in and turn the volume down as soon as the reciever turns on hope that helps you
Posted on Feb 25, 2010
  • Ryan Krampp
    Ryan Krampp Feb 25, 2010
    also dont buy an inverter lower than 300W it will still work but not as good try 300W or higher if you can find one
    Genius:
  • 1,199 Answers
Sure just be carefull how much power you put into them!
Please rate this answer!
Posted on Jan 23, 2009
If i hook up for 2 ohm do i use one speaker wire off amp bridged
Just use both speaker outputs, no need to bridge them,
Jan 25, 2012 | Hifonics BRZ17001D Car Amp
Replaced Headunit with after market one, but now the dash lights don't work, Fuses are fine, everything else is fine. Car is 1999 Mazda 323
Hi, there is a factory wire (red with a black stripe) in your car for illuminating the stock radio. This wire is not to be used in an aftermarket radio, so you need to make sure it isn't connected and also isolate and bare wire with electrical tape. Please let me know if you have questions, and thanks for using FixYa.
1999 Mazda Protege Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Yellow
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Yellow/Blue
Right Front Speaker Negative Wire (-): Violet/White
Car Audio Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow
Left Rear Speaker Negative Wire (-): Orange
Right Rear Speaker Positive Wire (+): Green/Orange
Right Rear Speaker Negative Wire (-): Green/Black
May 03, 2011 | 1999 Mazda Protege
I need to know what the sterio wireing colors represent for a 95 cavalier.
Thanks for using FixYa.
1995 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 13, 2011 | Car Audio & Video
Im trying to wire my radio but i cant find a diagram what color is the hot wire and what colors are the speaker wires
Hi, use the white (orange stripe) accessory wire to power the radio. The red (black stripe) wire is the hot lead used to maintain clock and preset stations for the head unit. The complete factory harness color code is below. Please let me know if you have any questions and thanks for using FixYa.
2006 Mitsubishi Raider Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: White/Orange and White (This vehicle uses the can data network for accessory turn on.)
Car Radio Illumination Wire: N/A
Car Stereo Amp Trigger Wire: White/Orange and White (This vehicle uses the can data network for amplifier turn on.)
Car Stereo Amplifier Location: Amplifier is located in the passenger kick panel.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): N/A
Left Front Speaker Negative Wire (-): N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Dark Green/Dark Blue
Left Rear Speaker Negative Wire (-): Dark Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Dark Blue
Right Rear Speaker Negative Wire (-): Gray/Dark Blue
Jan 30, 2011 | 2006 Mitsubishi Raider
Gauge cluster lights won;t light - replaced cluster, dimmer switch - did put new stereo in car? Fuses, bulbs all good. What could be the problem?
When you put the stereo in, what did you do with the red wire with a green stripe? The aftermarket radios don't always use these, so you have to wrap the ends, depending on whether or not you used a wiring harness. If that wire is shorted on the chassis, it will blow the dimmer fuse.
1995 Honda Accord Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/White
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: Yellow/White
Car Stereo Amp Trigger Wire: Violet/Red
Car Audio Front Speakers Size: 5 1/4?
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 6 1/2?
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Nov 28, 2010 | 1995 Honda Accord
Stereo wiring harness need to the colors and what they do? for a 1997 mercury mountaineer
cannot find 97 but found 98. Do these match?
1998 Mercury Mountaineer Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Light Green
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Amp Trigger Wire: Blue
Car Audio Front Speakers Size: 6? x 8?
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Rear Speakers Size: 6? x 8?
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 16, 2010 | 1997 Mercury Mountaineer
I got a ford aspire and a pioneer radio how do i hook it up
It is best to buy a connector pigtail for Ford, but you can wire directly using the below color code for the factory wiring. use the color code from the pioneer to match to the factory wires. If you have more questions, please reply.
1994 Ford Aspire Car Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black/White
Car Stereo Amp Trigger Wire: Light N/A
Left Front Speaker Positive Wire (+): Brown/Black
Left Front Speaker Negative Wire (-): Green/Red
Right Front Speaker Positive Wire (+): Green/Orange
Right Front Speaker Negative Wire (-): Blue/Orange
Car Audio Rear Speakers Size: 5 1/4?
Car Audio Rear Speakers Location: Side Shelves
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Brown/Red
Sep 29, 2010 | 1994 Ford Aspire
Radio harness is cut trying to install new radio need wire diagram
2003 Kia Spectra Car Stereo Wiring Color Codes
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Green
Left Front Speaker Positive Wire (+): White/Green
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): Yellow/White
Right Front Speaker Negative Wire (-): Yellow/Red
Left Rear Speaker Positive Wire (+): Brown/Black
Left Rear Speaker Negative Wire (-): Brown/Green
Right Rear Speaker Positive Wire (+): Light Green/Yellow
Right Rear Speaker Negative Wire (-): Ornage/Black
Jan 05, 2010 | 2003 Kia Spectra
Pioneer TS-W31C car speakers
i would recommend 12awg speaker wire
Jul 12, 2009 | Pioneer TS-W31C Car Speaker
Car radio
HI BBunk,
Sounds like the dead speaker took out the amplifier output too. You may need a new head unit.
Nov 13, 2007 | Elliott's Car Radio 50C564797 Car Speaker
JVC MX-GT88 CD Shelf System Logo
62 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
