Question about Samsung HLR5067WX 50" Rear Projection HDTV
Black line I have owned this tv for 3 years. The tv is working fine except for a black vertical line (approximately 3 inches thick) on the left side of the screen. The black line is faded (you can see the picture in back of the line). Please help.
I just had this problem with my Samsung 50' DLP HLR5067WX/XAA. Fortunatly it was still under warranty with Best Buy, so they fixed it for me. They had to order a brand new light engine. (or where the mirrors are, if i'm not using the right terminalogy) He said the problem is with one of the mirrors that has slipped (or slipping because overtime the black line will get thicker and thicker). I hope i'm saying it right, but it was with a tiny mirror that was slipping. Hope it's under warranty. I've also had 1x component plug burn out on me, my HDMI port went to ****, and he's gotta come back out because when he made the repair, the picture was reflecting too high up and to the left. (MLB 2k7 for xbox 360 - scores on top of screen are about 1/4th cut off). He said is next trip back to my house would result in me getting a new TV, so can't wait for his arrival! good luck with your tv
Posted on Aug 25, 2008
How do I resolve a problem with a black vertical line that's appeared approx. 2 inches from the left side of the TV screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 27, 2015 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
How can I fix a 3/4 inch vertical black line on my Samsung UN60D8000?
When liquid drips onto the x buffer boards (located along the bottom edge of the display panel ) the liquid Will damage the ribbon cables that are connected to the display panel. Replacing the display panel may be the only way to repair the tv. I've been in the tv repair business for over 30 years.... Dan
Jul 15, 2013 | Samsung UN Televison & Video
VIZIO 42" tv has thick black vertical line on left side of screen
The oven paper (referred as ovenable paper some time), is made of wood pulp, coated with food grade silicone oil. It features in smoothness, high-heat resistance and non- stick, etc. The brightness of baking paper is over 88. The sizing value of baking paper is above 0.8.Its strength is more than 3000.
Feb 23, 2013 | Vizio 42 in. LCD TV
I have a black approx 12 inch streak on the left side(facing tv) of my flat screen Bravia Sony TV . It is approximately 3 years old. It started as a brown panel..then became a fine lined multy colored...
sadly you have a bad panel. Sony panels carry a two year warranty.
your best hope is to call Sony and ask for a warranty extension to cover the cost of the part.
Apr 12, 2011 | Sony Bravia KDL-40Z4100 40 in. LCD TV
Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
Oct 10, 2008 | Televison & Video
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Techwood 42 plasma
if you still need the fix for this repost i have just repaired mine i had a 1 inch thick line just off centre .this is a easy fix no parts required.
Apr 19, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
I also have the same problem I phoned Samsung today to explain the tv was only 14 months old, they didn't wanna no because it was out of warrenty by 2 months. I am getting a black solid line down the left hand side of the screen. I ended up phoning Dixons were we bought it from, they have told me to get an independent engineers report done & send the report to them within 14 days. Dixon told me it was a known problem with Samsungs. They said they will fix it free of charge if they can if not they will send vouchers to the same value of the television. So beware stay clear of Samsungs.
Feb 03, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
159 people viewed this question
Henry  Thomas
Henry Thomas
