My monitor blink evryonce in a while and then the desktop will only show half the screen. After a while the monitor goes to sleep and says DVI - no input signal
  • 749 Answers
If you know little about electronics then you can fix it, just look for cold solder on the board and re-solder them. If you do not know electronics then you need a repair-man to do the job. No components to replace... have a nice day!!!
Posted on Aug 10, 2008
BenQ G2400W power save mode works find with DVI but will not go into power save using HDMI cable.
Look on the remote find the button under menu then on the screen find sleep timer or power saber and turn off.
Terry
Jan 31, 2015 | BenQ G2400W Monitor
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
When i supply power in my hp 1502 desktop and connect it with cpu than my desktop scree only show its going to sleep
1.check with a other monitor.
2.check the cabels should be seated tight.also the videocard should be seated tight.
3.the videocard or the monitor can be brooken check with a new or other monitor first.
Apr 17, 2013 | HP 1502 LCD Monitor
Keyboard and mouse not working and monitor going to sleep
HP Pavilion Slimline S3400f Desktop.
dont worry ALL PC end up like this,, all do.. sooner or later..
NO OS stated, XP"? never post without OS stated, or answer get 10x more harder, See? make it easy for the helper and get more help.....
no Monitor stated. (maker, CRT, LCD what?)
The monitor is not fibbing to you BTW, the PC did go dead or to sleep. seems its monitor monitor of some kind with DVI.
if the monitor works on other PCs then the monitor is not bad.
i Bet it works (old ones 2002, have a hidden deep internal sleep mode. and is not yours IM sure now) DVI IS THE ONLY CLUE THERE.
So PC is dead. this PC came with only VISTA new,
is it still VISTA?????????
HP has support on it still
here (carbon dated by me 2008, IIRC)
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-slimline-s3400-desktop-pc-series/3688715/model/3688723
this year,? get all those files and books there backed up
when HP support ends after 10 year rule, (be savvy?)
what keyboard USB or wireless keyboard mouse
use wired USB keyboards if wireless the battery is dead. easy no?
now in VISTA, go to Control panel, click power
turn off all sleep modes and all hibernate modes
the turn off screen savers, if turned on , disktop . RC right click
in display settings or personalize, turn off , need login to come out of sleep or screen saver.
try a real keyboard, that has USB cable yet? be first thing to do.
always keep a real keyboard, handy,,,
batteries fail. in all wireless devices like this (inside them)
luck you desktops have lies DIM fails. there are many.
http://www.pcdied.com/sleep-or-dim.html
one other way , and common is PC overheated.
all do that.
ever one not cleaned out every year,.
#1 all time cause of overheat and PC shuts down.
http://www.pcdied.com/overheated.html
Aug 11, 2017 | HP Pavilion Slimline S3400f Pc PC Desktop
My monitor seems to be stuck in sleep mode
This happens when there is no communication with video card. Check cables, re-seat video card, make sure monitor is set to correct mode. VGA (15pin blue), DVI (white), or HDMI.
Aug 28, 2012 | Dell desktop and monitor- Inspiron 530...
Screen Turn's on.You seen Acer load up Splash Screen for less then a min, Stay on until Windows Xp Load up screen then goes into sleep mode. Encontered same problem when I connected Xbox360 with HDMI to...
  • Hello chaleebradsh, the "Monitor" as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. "I hope this information is of help; thanks for using FixYa, paul7of9"
Jan 31, 2011 | Acer AL1717 17" LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
