Error Code: E7-21
I have Photocopier, Printer Sharp MX2300N. It was working fine... But one day it started to make noise and this error appear on screen....
Call for service: Error E7-21
Please help me.... Thanks
Plaese hepply this problem
Posted on Mar 09, 2009
SOURCE:
I just finish refilling toner on my AR-5127 Sharp photocopier and this error code H2-00 appeared what most i do to correct this code
I would check the fusing unit section, the heater lamp, thermostat and the thermistor continuity. Fix it first then clear the error code afterwards.
Jan 10, 2018 | Sharp Office Equipment & Supplies
Mx2300 write code f2-70 after replacing the black cartridge
F2-70 is indicating an improper toner cartridge K.
If you have just changed the black toner cartridge & the error appeared then the new toner is at fault.
Replace the toner cartridge with another cartridge, turn the machine off & back on & the machine should reset.
Hope this helps.
Dave.
Jan 09, 2017 | Sharp Mx-2300n Copier Color Mx2300n...
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Feb 25, 2015 | Sharp Ar-208d Duplex Copier, Printer,...
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Error code H5-01 sharp MX2300N
pascale_algu
Its a cause by continuous misfeeding. You better find the cause of that problem.
to cancel the code press program key(P), asterisks, clear key, program key . when the stand by for simulation code appears type 14 to cancel the trouble code.
Good Luck
Aug 13, 2009 | Sharp MX-2300N Color Copier
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
471 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
