Hi If it
won't show any error messages then try to reset it. To reset it press the reset
button (rubber disk) on the back of the machine. You should hear a click when
it engages. The machine will not start until it has cooled sufficiently. Hope
this helps...please post back for further assistance. Daniel
Reset button is not tripped? I am talking about a rubber disk that is located on the back of the machine...you have to press it to reset the dryer
If you already tried to reset it and also checked the continuity of the thermostat located inside the back panel then the issue is with the control board going bad and should be replaced.
Hi.
The machine is telling you that there is overfill, f2 and 4 are faults with overfill system. Lights blinking, pump running and controls dead also indicate an over fill fault :
"1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should
stop the operation of the dishwasher and run the pump if water is in
this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP
TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN.
(If the hose is not set up like this, water from the sink drain will
flow into the dishwasher and overfill the tray"
Here all diagrams.
Regards.
Ginko.
Well....my help was refused.
Goodbye.
Of course your help was refused, it's not a dishwasher lol ! Goodbye :P
Well, you could have got some more support giving a second chance.
Bye.
G.
My problem is with an asko dryer, not a dishwasher?
I'm confused?
My problem is with an asko clothes dryer not a dishwasher.
Hi Daniel,
The reset button is not tripped. Any other ideas?
Sincerely, brian
The reset is not tripped. Any other ideas?
Sincerel, brian
I am aware of the overheating reset button. That is not the problem. I have checked all of the wire connections, cleaned fan and interior vent system, checked door switch still no good. Do you have any other ideas?
Sincerely, brian
