What is the green plug at the back of the monitor that connects to the green plug between the pink and blue port at the back of the tower panel on a Compaq Presario is it the sound?
    Scholar:
  • 65 Answers
The pink is for a microphone and the blue is for a "line in" (much like a microphone). the Green plug is for your speakers. your monitor would only have this plug if it has built on speakers.
Posted on Aug 10, 2008
SOURCE:
Basic "background" colors are wrong:
Kathy...have you tried connecting another monitor to the same video card and computer? It could be...
1. Video card defective
2. VGA cable from computer to monitor defective...look for bent pins in plug.
The VGA cable from the computer video output carries three distinct colors...red, green and blue. Likewise one of these colors may not arrive at the monitor correctly or at all. The results being that all colors are incorrect.
Apr 13, 2011 | Westinghouse L1975NW Monitor
Samtron 55e computer desktop,monitor screen is pink and then with the blue coded plug that goes in back of tower is on it turns black and then when i take the blue colored coded plug out the screen turns...
Samtron (a former subsidiary of Samsung) as an entity no longer exists, and I have been unable to find any legitimate links to archived support documentation.
The symptoms you describe indicate that the monitor has failed. One way to verify this is to connect another, known good monitor to the same output on your computer. If that other monitor works, then yours does not and it is not the computer's output that is bad.
Looks like time for a new monitor.
Hope that's helpful.
Jan 17, 2011 | Samtron 96BDF 19" CRT Monitor
I dont know how to hookup my monitor to the tower
You will have two plugs coming from your monitor
One will have a blue plug that looks a little different, the other one will have a regular plug which can be plugged into your power surge or into a wall outlet.
The blue one will match up with a port on your tower. If you look on the back of the tower where all of the plugs go you will see one that looks similar but is opposite to the one coming from the monitor. Make sure you turn it to fit then screw it in and you should be good to go
Nov 06, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
HOW DO I HOOK THIS LOGITECH TO MY COMPUTER
Look on the back of your computer for GREEN and PINK and BLUE sockets.
PINK - plug a microphone into this socket.
BLUE -- plug an audio-device (CD-player, iPod, cassette deck) into this "audio-in" port
GREEN - plug your speakers into this "audio-out" port.
Connect the speakers to an AC power-outlet.
Oct 19, 2010 | Logitech X-530 Computer Speakers
Need a link for the directions on how to connect cables to the computer. serial #105255894
Connections
> Blue 15 pin or white 16 pin colour port is for monitor.
> 3 pin female port is for power cable for Computer Tower
>3 pin male power cable is for monitor
> Purple and green colour port is for Keyboard and mouse if they are ps2 (round connector) if usb then connect in any usb port.
>Small 3 colour ports Pink,Green,Blue is for sound.Connect only the Green colour cable coming from speaker to green port
>Connect the speaker Adapter cable to the wall socket for supplying power to speakers.
> RJ45 (Ehternet port-port which looks like phone connector but little bigger will connect Internet cable if you have internet.
Connect and Enjoy
Sep 08, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
My speakers stopped working after they were unplugged etc
Try the BLUE jack, then the GREEN jack. You won't hurt anything if you guess wrong. BTW, are the sub and speakers powered up? Pilot light showing they're on? Some speakers are powered by a USB port - any loose USB cables laying around?
Apr 18, 2017 | Creative Labs Audio Players & Recorders
I need help to to connect Monitor speakers to PC
if the speakers are built-in to the monitor then there should be a cord with a green phono plug on it---it plugs in to the green port on the back of the tower then you may have to go to control panel>sound and audio devices and make sure the volume and settings are ok
Apr 24, 2009 | Computers & Internet
No sound from headset plugged into monitor
From the manual I found, this model does NOT support ANY audio connections.
http://www.p4c.philips.com/files/1/170b1a/170b1a_dfu_aen.pdf
170B Product Features
- 17" color LCD monitor with excellent display performance.
- Dual input-accepts both DVI Digital and VGA Analog input.
- Advanced AUTO adjustment automatically optimizes picture quality.
- Wide viewing angle technology.
- 7.1 (181mm) small footpring with full detachable cables.
- USB Bay for upgrade to USB Hub.
- Optional protective cover to prevent LCD panel damage.
- Standard VESA mounting holes and optional tilt/swivel Wall Mount Kit.
But if yours does have these ports, I would suggest they are not for a headset, but for connection to the _PC_. I would suggest your model monitor has built in speakers, and the green port is the INPUT from the PC Speaker output. The pink goes back to the PC from the MIC which is built into the screen.
Apr 21, 2009 | Computers & Internet
Nonworking speakers
For your monitor with built in speakers, there should be a cable usually the plug is green in color, coming from the monitor which needs to be plugged to the back of the computer for the speakers to work. If you don't see a cable, then there is a plug on the monitor where a cable would go.
Yes you can connect external speakers. They plug into the back of the computer. There are usually round ports on the back colored blue, pink, and green. Figure: http://www.ultimatepcrepair.com/files/bsound.jpg (sometimes there is more, depending on your computer) The speaker cable plugs into the Green color one.
If you need more help just comment.
Aug 14, 2008 | Proview PS 776 Monitor
Open Questions:
-\&;-WINDSTREAM Customer Support Phone Number #{+ I:8OO-828-O294 }.U.S.A This windstream USA phone number is ranked #2 out of 2 because 7,728 windstream USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the windstream USA Customer Support department for problems like Where to buy, Complaint, Customer support, Repairs, Returns. As far as we can tell, windstream USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. windstream USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact windstream USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling windstream USA Calling windstream USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from windstream USA Customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with windstream USA's Customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare windstream USA's phone numbers against each other. Contacting windstream USA in General While I8OO8280294 is windstream USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach windstream USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact windstream USA.
Oct 16, 2019 | Best Computers & Internet
AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr
Oct 16, 2019 | Computers & Internet
-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }-\&;-AVG Customer Support Phone Number #{1*888*499*5520 }
Computers & Internet Logo
99 people viewed this question
Ekse
Alun Cox
