Hi there , just a quick but strange question ok here i go ... while taking my laptop to bits i thought i had taken every screw out but as i found out later i missed one but i tried to open the laptop and this resulted in me damaging the motherboard which the screw was held in and not to my knowledge ripped out the screw hole and a bit of the motherboard foil (not sure what to call it!) this is about 2 millimeters , i was wondering how i can repair this or can it not be saved thanks in advance for your help
  • 749 Answers
That can be fixed!... better ask assistance on that matter to a electronics technician... he will determine the right connections and place them on its proper place, also to check other problem.
good luck anyway!
Posted on Aug 10, 2008
    Scholar:
  • 65 Answers
It would kinda depend on how much of the motherboard is damaged. i've never been able to repair a motherboard myself, not without sending it to a specialist, and i'm not sure that it could be fixed. i would suggest to check the circuts on the M/B and make sure none of them were damaged and if it looks ok. then hook it back up and give it a try.
p.s. never force anything electronic, if it won't comeout theirs probebly something holding it in. examine further.
Hi, I have a HP pavillion DV6t laptop, the laptop fan makes too much noise. Yesterday I got this evil thought of opening up my laptop and cleaning the cooling unit. After opening all the screws on the...
I would recommend taking this to a computer repair depot, laptops should only be opened by a professional as they can be very temperamental and often a lot more complex than a desktop computer. Also I can not see the laptop so I can not say wether damage has been done to it or not.
Feb 03, 2011 | HP Pavilion dv6t Notebook
Just a quick question, I need to replace my keyboard on my acer 5534 laptop, found a new one, have it ordered, how easy is it to replace the keyboard or should I let someone else do it?
pretty simple turn off the pc flip it over take ur battery out then there will be holes with screws with little keyboards beside them indicating the mounting screws positions remove them open the laptop pop the key board out some models will need another piece of the bezel to be removed to achieve this if it seems to daunting get some help and good luck with this
Dec 19, 2010 | Acer Aspire 5500 5570-2609 Laptop
Hi, I've been given a hp compaq nx9010 notebook computer which works perfectly except the audio mute button and LED don't work at all. The up/down buttons work fine. What could be wrong? The switch feels...
The ribbon cable to those quick buttons may be broken. I've seen that happen more than once. the only way to test it is to remover the battery, Take out the screws in the battery compartment that hold down the Power Strip & Quick Button strip. Flip the laptop right side up, and gently pry up the strip that has the power button and quick buttons on it. Once that's done, try wriggling the ribbon cable back & forth while a song or some other sound file is playing to see if you get sound. You do this at your own risk though. I once shorted out the power button circuit board doing this. If the Ribbon cable is bad, then you can get a replacement on Ebay.
Mar 13, 2010 | HP Pavilion dv6000z Notebook
Paper does not feed into printer
Printer Lexmark X4550 not taking paper, (Quick Fix)
Hi, yes my printer had the same problem with the pick up rollers not taking paper,
and thought it would be a simple job to adjust the springs inside the printer? But no, I could not find to open the printer. So I devised a simple modification using a
thin flat spring I had taken from an old windscreen wiper blade. see instructions
Good luck, bigvern
Jan 10, 2010 | Lexmark X4550 Multifunction Wireless Color...
How to take apart the diswasher to clean it
This is a 5 step process.
1 Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports).
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly out.
3. Remove overhear conduit. There is one screw at the back and one at the top (Philips #2 bit). Rotate the whole assembly 45 deg right (Clockwise) and lift off of the centre post. It can be taken apart to clean.
4.Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift the whole plastic assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at the front left (Under center assembly just removed). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter & filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc up. Clean thoroughly. Run a 'quick rinse' cycle with everything out, to clean the inside.
Reassemble.
Jan 01, 2009 | Kenmore 15129 Built-in Dishwasher
FEQ332ESO no heat!
I got a thermostat for 20 quid which I thought was a bargain. Have taken the back cover off and found all the parts but when I try and connect it the wires seem to be very slightly too short and I'm not 100% positive where the earth goes.
A friend took the bit off a few weeks back to see if he could get the same part !!!! so I didn't see how it was originally.
where did you get the manual??
hope you can help
cheers
Nov 23, 2008 | Candy CDC266 Dryer
Replace park lights on 1998 camry
If your dash lights work, your park light fuse is OK.
Jul 27, 2008 | 1999 Toyota Camry
CMOS BATTERY
I couldn't find a parts breakdown for that model, but 99% of all laptops will have a few screws hidden under the keyboard.
Some models, you have to take the LCD hinges off too.
Also, remove all panels from the bottom, and remove any cards, cd-roms, etc that may be in them. Basically strip the laptop down to nothing. You're bound to find a few screws you missed.
Jan 09, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Light blinks 8 times
Best Solution by Guest worked!!! Great job and Thank you!
Nov 14, 2006 | Sony KP-51HW40 51" Rear Projection...
Computers & Internet Logo
David Payne
David Payne
