Question about Trekstor i.Beat cebrax RS 1 GB with FM Transmitter MP3 Player
I.beat cebrax 1gb problem
The above memory stick which will turn on but after between 3 to 10 secs it shows either the shut down screen and turns off or just shuts off any way..
then it will just keep starting and turning off untill i pull the battery out or put the key lock on.
ive rechaged my battery but hasnt improved at all.the only way i can get i to act noamaly though ( at least briefly ) is to conect to computer and delete all music stuf and relaod it. but it works fine for a while but just goes back to square one..
any one able to help ??
  • Anonymous Feb 03, 2009
    the above memory stick which will turn on but after between 3 to 10
    off any way..
  • jez stanley Feb 03, 2009
    i sorted the problem on my ' I.beat cebrax 1gb '
    it was the firmware.
    i downloaded it from a site and loaded it onto the player.
    cured it and still works fine now..
Posted on Feb 03, 2009
6ya staff
SOURCE:
I've followed your instructions on shutting down my tablet and trying to unlock the lock icon with no avail. What next?
If you tried sliding the lock icon and it doesnt move in any direction, chances are that the tablet is frozen. In that case, hold the on/off button for about 5 secs or until the tablet turns off (it will vibrate as it turns off, this is different than just pressing the on/off button) or offers you an option to shut it down. Wait a couple of secs, the tablet will show the booting screen and then allow you to work with it, not just showing you the lock as soon as you turn it on. If it shows you the lock without the booting screen shown first, this means that you didn't really turn it off properly. Try holding the on/off button longer!!
Mar 14, 2017 | Tablets & eReaders
I have a HP a1514n media system with 2 - 512 sticks of ram. I replaced one of the 512's with a 1GB stick and my system only shows 1024 ram available. I checked the settings in startup and it shows...
First of all, make sure you have the right memory - 240 pin, DDR2 SDRAM, PC2-4200 MB/sec.
Your machine should support the memory as it has two banks of 1. Sometimes it is simply a sequence problem. In older machines with mixed memory, I always put the largest and fastest in the first slot. You might try just reversing the memory.
Jul 19, 2011 | HP Pavilion a1514n (EX269AAR) PC Desktop
I put in two sticks of 1gb pc2-4200 533mhz and the computer started, began to load, then stoppped. i shut the computer off, turned it back on and nothin. i removed the second chip and replaced it with the...
You have not mentioned the manufacturer and the model of the PC. The general answer for this question will be :-
1. to check the maximum memory capacity of the PC
2. In some PC's you have to use 2 identical memory sticks otherwise it would not work.
If not this 2 then 1gb memory stick is bad.
Please re-post this with the manufacturer and the model of the PC so that we can assist you in a better way.
Was this helpfull ?
Please rate this.
Mar 16, 2011 | Computers & Internet
Hey I have 1GB Memory Stick and can't send music or photos on memory with program sony ericsson pc suite when i turn on my phone it says Warning!All content on Memory Stick will be lost ...
you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory stick (use quick format), and then use above mentioned software to scan again the memory stick and recover your files.
Mar 03, 2011 | Sony Ericsson K800i Cellular Phone
How do I format my pro duo memory stick. I have xp.
Insert in card reader.
Bringup "Computer" on screen, right click Mem Card Icon, menu should show "Format".
Dec 26, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Computer power shuts down when I try to turn it on.
make sure the memory is seated right and not out or loose make sure all the cables are secure and connected
May 05, 2010 | HP Pavilion s7600n PC Desktop
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
No post no video Beeps once every sec. The first few times it boot I had video. Then lost video now I have it back. it will run all day when in the bios. But outside the bios trying to load Windows XP home...
Hi...
Actually the problem is the memory witch is beeping every seconds during turning the laptop on. Check your memory stick, remove the memory stick, clean from dust. Reinsert it try to use the other memory slot. If the problem is still occurs the memory stick is bad or faulty already. You need to replace the memory stick.
Thanks for using fixya
Regards
PCmania
Aug 15, 2009 | Toshiba Computers & Internet
Dell computer won't start up.
if you have 2 memory sticks, (i.e. 2 ram sticks that are 2 gb each) try putting on in and start it.  if it does not work try this.
remove all power supplies (cord and battery).   hold down the power button for 30-60 sec.   after that plug the power in and try turning it on.
Mar 09, 2009 | Dell Inspiron 5160 Notebook
Trekstor i.Beat cebrax RS 1 GB with FM Transmitter MP3 Player Logo
366 people viewed this question
Top Trekstor Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Trekstor Audio Player and Recorder Expert? Answer questions, earn points and help others
