Question about Mitsubishi WS-65511 65" Rear Projection Television
Tv ws-65511 volume stuck
My big screen tv was doing fine until we hooked it up to cable box. My mom loves close caption. It's on. Volume is stuck. remote will not work. cannot get to menu, with remote or front panel. i have tried everything i know . all i can pull up from front panel is device menu. VOLUME IS STUCK AT ONE LEVEL . I PRESSS VOLUME BUTTON AND IT GOES RIGHT BACK DOWN TO SAME LEVEL. PLEASE HELP ME IF YOU CAN. THANX! PRISCILLA
  • swaz11 Sep 16, 2008
    We lost our remote's ability to control the tv overnight. Front panel allows us to turn tv on and change channels but volume is stuck and devices are not functioning. TV repairman replaced the DM Module capacitors - 7 and it worked for 1 day then we turned it off for the night. The next day it was back to the same problem. I don't think the repairman knows what's wrong either. HELP!!
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Posted on Aug 27, 2008
What do I do when my Magnavox flat screen TV volume is going up and down by its self?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 14, 2017 | Magnavox Televison & Video
No volume on SEIKI TV
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://homenol.blogspot.com/
http://electrotechnician.blogspot.com/
Jan 13, 2017 | Seiki Televison & Video
I have a 50" Panasonic TV HD vega and the screen keeps going red with just centre image! Can't get it to work!
Sounds like display panel fault. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jan 13, 2017 | Panasonic Televison & Video
Why can't I get the DVD player to work? I have it hooked up to a cable box.
im wondering why you did not connect it to the tv ?? but instead to cable box , does it have a pass thru capability ?? does it need to be off to pass thru ?? as most dvd player don't have a rf output but instead use a hdmi or composite signal output , would it not be easier to connect one of these to a spare input on tv then when u want to use dvd you only need to select the proper input from tvs source button to view the dvd ??
Jan 10, 2017 | Sylvania Televison & Video
My lg 65uf8600 closed caption is on but in my settings it is turned off
If internal speakers are turned off, CC may turn on by default.
Jan 10, 2017 | LG Televison & Video
How do I knock subtitles off my Samsung tv model number LT32E310 thank you
The "subtitles" are closed caption (CC) displays that usually are enabled/disabled as part of the initial set up procedure.
Jan 09, 2017 | Samsung Televison & Video
When CRT JVC TV is first turned on, the image looks shrunken and warped, eventually, the image looks fine. What to fix?
SMPS fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Check all the electrolytic capacitors.
May 26, 2014 | Televison & Video
How do i fix my elonex tv
switch off.wait for 5 mins.
press & hold power button till it turns on then off.
ifno luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
May 04, 2014 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
I have a bell satellite reciever, I am trying to hook up a second tv to the hdmi output, I hooked up a hdmi splitter! but it does not seem to work. I get a picture on only one tv and no sound. when I...
NO YOURE NOT WASTING YOURE TIME YOU JUST NEED TO PUT THE MAIN CABLE FROM THE STAELLITE INTO TO WHERE IT SAYS IN AND THE OTHERS CABLES IN WHERE IT SAYS OUT AND OUT AGAIN
Apr 21, 2011 | Toshiba 26HF85 26 in. Television
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
252 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
