It is 1 of 2 things here,your either not using rinse aid or your heater is not on.Make sure you have selected the option "heat dry". Please Rate This !
Comments:
Aug 25, 2008
- ok I see you have rinse aid in, so run a check on your heater element .Remove the bottom panel to get access and screws that hold the frame to cabinet,you are going to have to pull the dishwasher out so you can check for voltage at your heater.If you are not skilled at this ,DONT TRY !! The experience I have is to give the best advice and not lead you into a disaster.Please know that it can be one of the most frustrating appliances you can work withbecause of the tight quarters.If you need further assistance , I'm here to walk you through this the best way possible. Please rate this !!!
will not drain. Checked lines-no clogs. always leaves about 3" of water in bottom just below...
(More)
will not drain. Checked lines-no clogs. always leaves about 3" of water in bottom just below the heater element.
I have a frigidaire dishwasher. And it sees like a lemon to me the arms arn't spining. There is no...
(More)
I have a frigidaire dishwasher. And it sees like a lemon to me the arms arn't spining. There is no water pressure problem..nor any holes cologged any more, so what can I do to get them spinning agin? Holliday dishes stacking up.. Cis Blackwell
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
