Question about Denon Audio Players & Recorders
I have a Denon DM35DAB CD receiver. Having switched on from standby it seems that virtually every button results in switching back off. E.g. if I press disc eject, or try to change function to the radio - off it goes. It will generally play the CD that is already in the machine - but via the remote not the play button on the unit - but won't let me change the CD. I am getting bored of the same CD! Any ideas?
  • 2,071 Answers
Just open your remote control and clean it with an alcohol, and do some resolder works of the parts joint , maybe there are already cracked in the remote that why is not works properly..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Aug 10, 2008
Denon CD not switching on
The lightening causes a strong electro magnetic field to build up very quick and also break down. This pulse can induce a huge current in electronic equipment, causing damage in semiconductors.
The damage can be in any of the components in your Denon. It also could be only one semiconductor. FET's and MOS FET's are the most vulnerable.
Without a service manual, tools and the Denon on my desk it would be impossible to tell what is damaged.
But I would trust not any component in the player.
Also read ESD and what happens direct and what can happen when times goes bye.
Jul 22, 2014 | Denon Audio Players & Recorders
Denon not switching on
Talk to Richer Sounds hi fi there will be a shop near you if you are in the UK.
Denon AVR-3200 wont go into standby mode
Not sure what you mean by standby mode. The power button on most of the audio remotes I deal with merely turns the equipment on and off.
Nov 24, 2013 | Denon AVR-3200 Receiver
DENON AVR 1507 short?
unplug it, let it set for about 15 min., plug it back in and see what happens. Hopefully it will recycle itself. If that fails, with your theater remote, you can pull up it's functions screen on your TV, and probably return it to factory default settings. That would be a last resort for me before seeking professional help. Good luck. . .
Jul 27, 2017 | Denon AVR-1507 Receiver
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
My remote for a denon 2805 doenn't seem to be working. When I try to change to say DVD it doesn't work. The CD button just lights up. I also have a Harmon remote that I have learned the commands on but...
Check on e-bay for a replacement, call Denon tech support and have them send you a new one, or buy you a universal remote and put in the code from their manual for your Denon receiver.
Oct 26, 2009 | Denon AVR-2805 Receiver
Has power but keeps switching to standby
Disconnect all speakers at the receiver and turn it back on, if it stays on post a comment and I will help you troubleshoot further. If it still cuts out, it needs to go to service for repair. Hope this helps.
Aug 21, 2009 | Denon AVR-1907 Receiver
What is the master reset code for the denon avr 1508?
Turn the unit off by main switch (not a standby button).
Press and hold "Speakers-A" and "Speakers-B" buttons and turn on main switch.
Display blinks.
Release the buttons after 3 seconds.
Receiver is reseted.
Jul 20, 2009 | Denon AVR-1508 Receiver
Denon av receiver switches off
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Feb 19, 2009 | Denon AVR-2801 Receiver
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
133 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
