Question about Yamaha RX-V1700 Receiver
Main Remote is on zone 2. I have no active zone 2 how do I get it back to main on remote
  • 2,071 Answers
Just unplug your unit for two hours and plug again and reset it..
hope this may help;
Posted on Aug 10, 2008
Bose rc48s2 remote not receiving signal
make sure the lens on the remote and the one on the Bose are clean. If that does not work, replace the remote. Buy a used on on ebay.
Dec 21, 2013 | Bose RC-48S Remote
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
Can't control zone 2 volume or choose to turn it on and off with the remote
For zone 2 you need separate zone2 remote control or there should be a zone2 switch on main remote control.
Feb 06, 2011 | Denon AVR-587
My Denon AVR2308 is frustrating me. I am running two zones (5.1 in main and zone 2 out of rear surround). I have made the audio setting to allow Zone 2 on/off, but i am stuck on how to turn sound off in...
Greetings,
Unfortunately the AVR2308 does not have the zone 2 video output connector needed to pass video to a second zone. The AVR2808 was the first receiver in that year lineup to offer a video output to a second zone. There are many different types of video outputs on that receiver, but they are all associated with the Main zone. This is why you loose the video when you shut down the Main zone. With respect to your Zone 2; the small remote that came with the receiver should have all the power and volume features you need to operate Zone 2 while keeping the Main zone turned off. The only audio that can be passed to Zone 2 though has to be in an analogue format (using the red and white RCA connections). This receiver does not pass digital audio onto Zone 2. Best of luck!
Aug 21, 2009 | Denon AVR-2308CI
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
Yamaha RX-V2500 completely shut down
Sounds like the volume control on zone 2 is your culpret. You should set up zone 2 to have a "fixed" output instead of "variable" it's in zone 2/3 setup. whats happening is you are overloading the volume control from the zone volume on the receiver and getting feedback to the receiver and shorting it out. What you do is put zone 2 to fixed output. set the vol control to 3/4 then adjust the vol to relatively loud and exit out of settings. this will be your max volume setting. Now, on to your problem.Unplug the receiver. There is an internal fuse that could have blown, not to likely but it's possible. You have to take the top off the receiver with a #1 phillips or a T10 torx they vary. It's about 7 screws, pop off the top and look from front to back, you will see 1 or 2 fuses near the AC plug port. Sometimes they are gray or white and you cannot visibly tell if it's bad. If you have a multimeter, set it tone resistance. Then put your leads on either side of the fuse, if you hear tone the fuse is ok. If not check your leads by touching them together and you will hear tone then test again. If you don't have tone, your fuse is bad. Radio Shack should stock the fuse you need. If you don't already know this, there are 2 Power switches for your unit. Front of receiver bottom left corner "Master Power" and normal Power switch "Main Power" check them both. If your fuses are good and power is good, you have bad transistors internally and it needs to go to service. check www.yamahausa.com support and service, and you can find the closest authorized service center to send it to. If you mail it out directly to the service center rather than taking it to a dealer, you will save some money and get it back faster. Lastly, pull your zone 2 volume control and look for black marks on it or white chalky substance. "oxidation". If you don't mind spending a little money on the system, hardwire the speakers thru and replace the volume control with an IR receiver. If you could control the zone from the zone by pointing the remote at the volume control you had an IR vol control. You really didn't need the vol part. Xantech or Proficient make good IR receivers that aren't too expensive and will keep this from happening again. If you need any more help, I am a Yamaha Dealer, let me know where your located and I can send you to a good service center. Just post a comment and I'll get you the info you need. Hope this helps
Apr 19, 2009 | Yamaha RX-V2600 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Feb 21, 2008 | Audio Players & Recorders
Problem: I am trying to Hook up my RX-Z9 and get sound out of MAIN.
Try pressing "Main A" or "Speakers A"-button on the remote-control (slide the shield at the bottom)
Nov 14, 2007 | Yamaha RX-Z9 Receiver
Yamaha RX-V1700 Receiver Logo
101 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
