We just bought our Admiral Top load washer 1 week ago and now the water will not fill the machine to do one load. We have stop using the super capacity setting and are trying the medium capacity setting to see if this will solve the problem. So far our machine will only fill with water and seems to drain out before it starts washing
  • mdbvizion Aug 11, 2008
    Thank you
    Yes, that did fix the problem and everything seems to be working great!!!!!!!!!!!!!!!
    Dale
    Genius:
  • 1,028 Answers
Ck to see how far down in stand pipe drain hose is shouldn't be more than 6-8 in also be sure stand pipe is at least the height of washer edge above floor there also needs to be small gap between washer hose and standpipe ..if hose is too tight in stand pipe or too far down or not high enough from floor a problem with siphoning may occur
Posted on Aug 10, 2008
SOURCE:
Heavy duty super capacity plus
Check water level switch and associated hose, see my other posts on this solution.
Aug 19, 2013 | Admiral AW22 Top Load Washer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
The washer water won't turn off once it has filled for all three load sizes.
Might be the water inlet valve at the back of the machine where the hose connects too, replace the valve and see if that fixes the prob
May 09, 2009 | Admiral AW22 Top Load Washer
Admiral Top Load Washer Model LNC6762B71 overflowed
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Feb 28, 2009 | Admiral AW22 Top Load Washer
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Admiral Top load washer won't agitate and squeals
Sounds like the gearbox, unfortunatly this is sealed and is cheaper to replace the machine, presume the machine is quite old.
Jun 28, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
