Question about Jenn-Air JMV8208A Microwave Oven
Hi! How do change the bulb in a Goodmans GSS20 microwave?
  • Anonymous Dec 20, 2008
    Replace bulb in GE JES1136wl01
Don't know about the Goodman's. But I can give you a tip: it's probably easy. Just take the thing apart and look around. The GE JES1136WL01, I have disassembled right now on my recliner chair, so I can tell you all about that one.
1) Take the top of the case off. There's some Phillips screws, and two vandalproof ones: torx with a post in the middle. So you can have the right bit ( http://www.mcfeelys.com/product/VDB-1130/Security-Driver-Bit-Pack-30-pc ). Or, plan B: often our helpful Taiwanese friends didn't make the post quite long enough, and so apply enough pressure and you can remove it with normal torx (a.k.a. star) bit. Plan C: get a drill, a smallish drill bit, and blast that post out; then the torx will unscrew it, or if you don't have a torx even a small flat head (slot) screwdriver of the right size.
2) Look at the side with all the interesting stuff, behind the LED screen. See the off-white plastic thing telling you about "Max 40 Watts, Min 40 Watts"? On top of that is the black base of the light bulb, held down with two long thin white plastic clips.
3) Press the clips in, take the bulb out. Unhook the power leads too, of course.
4) Put in the new bulb. There's the kicker: where did you get your new bulb? I don't know. It's a T170 bulb, and the black base and the bulb is all one piece so stop trying to yank or screw it apart. You may have found one here:
http://cgi.ebay.com/NEW-T170-MICROWAVE-OVEN-LAMP-LIGHT-BULB-240V-25W_W0QQitemZ280177924502QQcmdZViewItem
or here:
5) Stick it in. Undo steps 1, 2, 3.
Posted on Jan 15, 2009
  • Jenn-Air Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 12, 2008
How do I change light bulb in Kitchenaid Microwave KCMS1555RSS
You will need to remove the cabinet to change the bulb, the part number is 4359741, now the bulb is part of the base so the part number is the correct part for this model. Good luck
Mar 14, 2015 | KitchenAid KCMS1555SSS Microwave Oven
How to change bulb
Hi
we have two vintage vacuum cleaners a 612 from 1949 and a 652 from 1959 Does anybody know how to change bulbs on the headlights ion these machines ?
Jan 07, 2014 | Emerson MW8107WA Microwave Oven
Need a users manual for a Goodmans st101ss microwave please.
go to www. retrevo.com + www. manualslib.com
God bless you
Nov 27, 2013 | Goodmans Microwave Ovens
Missing Goodmans cs20 manual
Please refer these queries to Goodmans
Apr 13, 2013 | Microwave Ovens
Where can I find a manual for a goodmans microwave
Try Googling (Goodmans)(GS200)(manual) without parens.
Jun 20, 2017 | Goodmans GS200 Microwave Oven
I have lost the operating manual for goodmans gss20 microwave could you help .thanks.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Jan 07, 2011 | Microwave Ovens
Microwave does not warm but the grill works i have a Gss20 goodmans microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
k
Apr 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Spare Part needed
Check at:
http://www.espares.co.uk/search/microwaves/goodmans/p/1095/807
I did not see the part you described but they may have a substitute to suggest if you contact them.  Happy hunting.
May 30, 2009 | Microwave Ovens
Just bought a display model GSS20,and it came without a manual.Is there a downloadable version?
yes if you go onto the manufacturers website you can download a printable version or as customer services for to send you 1 and they should oblige,hope this helps
Jul 30, 2008 | Microwave Ovens
Jenn-Air JMV8208A  Microwave Oven Logo
515 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
