Question about RCA Audio Players & Recorders
Cannot get FM radio to come through. CD plays fine but cannot get any radio station to come through. Just static
  • 2,071 Answers
You must open your receiver and go to the tuner.Clean the tuner with the used of an old tooth brush with an alcohol and do resoldering works in the tuner section,maybe solder joints is cracked or loose or cold.It is a loose connection or cold solder and cleaning problem this is the main caused of no sound of FM radio. Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 10, 2008
Why do radio stations have static?
Why are all my radio stations static? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Feb 20, 2014 - on all of the radio stations in my car, there's a static background noise. no ... It sounds like the receiver has lost it's sensitivity. either that, or the ... Why am i still getting static on my radio?
Sep 16, 2013
Why are all my preset radio stations static?
Sep 3, 2012
Why do AM radio stations have so much interference and static ...
Jul 2, 2009
My car radio makes so much static noise with engine running, but ...
Jan 17, 2007
More results from answers.yahoo.com
Dec 12, 2015 | 2005 Dodge Durango Limited
Electrohome ean 0s700 radio wont play
Check the aerial connection. Some FM radio's will mute the static and only pick up strong signals. If it is an FM AM radio check the AM radio. If that is OK and the connection's are good you might have faulty Tuner circuit, which would need a trained technician to look at.
Dec 10, 2014 | Audio Players & Recorders
Radio static
Check your antenna. If the mast is not extended, your reception will be limited. try an AM station, usually a local AM station will still come in even with the mast down. Have you tried playing a CD (if equipped) ? If that plays well, you've confirmed lack of reception as the problem. If the mast is extended and you still do not have reception, the antenna plug my have come out of the back of the radio. The requires removing the radio to check.
Sep 30, 2013 | 1997 Honda Accord
Fix car radio static
old post, and my first radio noise post.
im an old radio guy USN, and ex ham.
Q1: AM or FM? (even on cassette or CD?)
1: bad antenna, and for sure, there are upgrades !
2: too far from station, AM is worst for static, but FM has shorter distance for same station power. (I heard XERB in VietNam! AM)
3: bad radio. (rare for both am and fm bad)
4: bad alternator can sing, play with throttle and it sings higher for higher RPM bingo. stop engine, singing gone?, bingo. Alternator.
5: and last ignition noise, so stop engine still have ignition popping sounds. no more? , then Ignition noise, clicks or pops. (spark)
6: noise has 2 sources , radiated or conducted.
if conducted on power line, 12v to radio , we can buy a filter to stop that.
older cars do this. what year is yours. a honda what a 73 civic?
Aug 22, 2013 | Honda Cars & Trucks
I noticed static on fm station on my radio. the
i would get the alternator checked, sounds like its leaking ac current which can also kill the battery
May 04, 2010 | 2006 Subaru Forester
What fm station do I set my radio on?
i have a ford explorer, 1995 it came with a 10disc cd changer only trouble is we dont know what radion station we need to use for it can you help?
Apr 15, 2010 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Cannot play ipod in 99 daewoo lanos
instead of pressing the left/right scanning buttons hold them and then let go when you want to stop
Aug 15, 2009 | Daewoo Lanos 1999 Car Radio/stereo...
No radio reception in office.
most portables have a very weak FM receiver, and a building interior tends to block a good deal of signals. your best bet is an old fashioned unit with a large retractable antenna.
Jun 12, 2009 | RCA RP7887 High-Performance Super Radio
AM static
the easiest way would be to move the radio farther away from the furnace.
Sep 13, 2008 | Bose Wave Music System CD Shelf System
Lots of static when playing over the stereo speakers, and the screen seems loose
sorry but what u have is called a fm modulator some are adjustable some not go to your local car audio shop to find out or take your headunit out and look behind it if so tune the fm mod to a different station one thats not being used there are three preset station on the fm mod but remember just because theres no station on that radio channel were u live dont mean there wont be one when u go into town thats the bad thing about fm mods best thing to do is get a indash cd dvd radio and as far as the lose screen just hand tighten the screws flip down the screen look up there should be 4 or 6 screws there just tighten them up a little this is normal
Dec 18, 2006 | Farenheit MDM-830CM Car DVD Player
98 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
