Question about Tomtom GO 910 GPS Receiver
TOM TOM 910 won't charge/turn on
My TomTom910 wont switch on. It was charged when I last turned it off. The green light comes on but won't stay on. Help! TIA
  • 3 Answers
There is a little push button on the back. use a niddle and push that down at the same time hold the power button. you will hear the unit turning on itself and then it should work fine
Posted on Feb 18, 2009
TOM TOM 910 TURNS ON BUT IMAGE OF TOM TOM STAYS ONSCREEN WILL NOT TURN OFF
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds .
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Jan 27, 2011 | Tomtom GO 910 GPS Receiver
Tomtom910 won't turn on. I replaced the battery, charged it and now it won't turn on.
Try doing a reset. The reset hole is on the bottom of the TT 910. Use a paperclip to do the reset. Gently push the paperclip into the hole until you feel a click the hold it for 30 seconds. That should do the trick, unless the unit is not actually charging. The green light will come on but not charge because of a bad connection on the motherboard on the negative side.
Jun 20, 2009 | Tomtom GO 910 GPS Receiver
Blank screen but green light is on
I have had this on my 910, It turns out that the motherboard needs replacing and after looking on here its quite common.
Its quite esay to replace and perhaps worth changing the battery whilst your in there as well.
Google for instructions or flick through this site.
Apr 15, 2009 | Tomtom GO 910
Common problem with TomTom GO 910
Others have found this site helpful with the 910
Dec 12, 2008 | Tomtom GO 910
TomTom910 not charging
This is a common problem with the 910. Try putting an obstacle in the way of the wire to keep it on. Better still is to not use the home dock at all. Just plug the home charger in to the windscreen mount (device connected of course!) and charge it that way. You get a better charge and it will stay on.
Nov 16, 2008 | Tomtom GO 910
Tomtom
stevi at the back of your tom tom where your windscreen dock goes there is a small rubber bumper if you look to the right and down you will see the reset button it is a small hole above the dock socket. sandy
Feb 21, 2008 | Tomtom GO 910
Tomtom GO 910 GPS Receiver Logo
1,351 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
