Question about Iwill ZMAXdp Dual Opteron nVIDIA Barebones System (Black) (FA64900000)
Faulty psu -zdmax dp .. where can i get a new psu..
Completed building my zdmax dp with dual opterons, 2 days later psu blown up! ????????brandnew barebone ! now is the problem where can i get a new psu.?
I have 2 Zmaxs Dps,1is nearly new and has been tested,(spec on request) Colour RED. The other was working but i am selling it as spares because i intended to use it for parts.( BLACK). I think the Black one is also O.K. except sometimes you have to fiddel with the Power lead to get it to run.
Posted on Jan 01, 2009
  • 101 Answers
For uk and market try:
www.scan.co.uk
Posted on Aug 10, 2008
First boot up works fine, then 5 minutes later.. the pc turns off instantly (no blue screen) reboots for about 5 seconds then turns off again, then boots up for half a second then doesn't reboot at...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 21, 2011 | CORSAIR Builder CX500 (CMPSU500CX)...
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
Intel cpu comparable to "Dual Core AMD Opteron 1212HE"
This is an AMD 2nd generation Opteron CPU, running at 2GHz. It is a single core device. So a comparison would be against Intel business CPU - the Xeon, again compare against a single core.
Apr 02, 2009 | AMD Opteron Dual-Core 1212 HE 2.0GHz...
Faulty Panasonic Projector
90% that this is a bad psu !
had mine fixed today with used psu from ebay.
try to find a faulty pt-ae900 for a exchange psu !
60€ faulty projector + 60€ psu = 120€ for pt-ae900
hooray :)
cheers,
tobias
Dec 31, 2008 | Panasonic PT-AE900U Multimedia Projector
Dead Kiss DP-1500 Player
The problem is a well known weakness of all Kiss DP 15xx and DP/VR558 players.
The PSU (power supply unit) can't stand the heat and will fail typically after 1-3 years of operation/stand-by. At first the voltage falls fading the light intensity of the front panel, then odd malfunctions occur, and finally the unit ceases to work.
I own own of each, and they are close to identical as to the PSU and both have had the same problem.
The condensators of the PSU are of a inferior brand and typically 3 or more of them will "burn" leaving a bulge at the top end of the cylindrical component or alternatively leak a dark brown resin-like substance onto the print board.
A complete set of new condensators can be had for approx 5 euros and at that price leaving some of the original condensators unchanged seems unwise.
Read all about the fix at: http://www.mpcclub.com/wiki/index.php/Psu
Be advised that opening the cabinet voids any warranty, but as Linksys the new owner of the Kiss brand refuses to repair- or pay for repairs this is of little concern.
Jun 10, 2008 | Kiss Technology DP-1500 DVD Player
K8n-lr motherboard
1 long beep and 2 shorts beeps indicates a problem with your RAM. If you have more than one RAM chip, remove one of them to rule out a faulty chip. If you only have one chip, remove and reseat it. For clarity, you can find the manual for your board at; http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8N-LR And the Asus general motherboard troubleshooting manual at; http://support.asus.com/images/document/ts/E2437_MB.zip
May 30, 2008 | ASUS K8N-LR Motherboard
Faulty BMW tv monitor
Check for bad connections.
atdlee@netzero.com
Dec 05, 2007 | XO Vision GX733 7.3 in. Car Monitor
Power issues on new build
Hey mate smart PSU next time just unplug your power cable for about 5 secs plug it back in and try
May 09, 2007 | Atrix PSU 500 BLU PSCI-500BLU RET...
Iwill ZMAXdp Dual Opteron nVIDIA Barebones System (Black) (FA64900000) Logo
328 people viewed this question
Top Iwill Computers & Internet Experts
Alun Cox
Josh Whitehead
Josh Whitehead
David
David
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
