Question about Asrock P4I45GV R5 Motherboard
Buying RAM to my ASRock(845GV R5.0) Motherboard ?
I know that my motherboard can support 2GB RAM but i want 2 know whether it can support more than that.
can u tell me the best RAM (which can compatible with FSB).
configuration ---------->
1) Motherboard Name : ASRock P4i45 GL/GV/PE
2) Processor : Intel Pentium 4, CPU 2.40GHz.
3) current-- RAM : 512 Mb RAM
plz tell me d best RAM which has better FSB than that, if possible & most importantly it must support my Motherboard ASRock(845GV R5.0).
one more thing is that now i want to buy at least 1-2 GB RAM
so ur guidance plz,
  • 4 more comments
  • govee Aug 10, 2008
    [ graphics -intel extreme graphics ---memory max.64Mb ] what does this mean ?
    will it enhance my PC's performance?
    [ 3 PCI slots, PCI 2.2 , AMR1 slot ]<--------- what should i use out of this so that i can get the best performance ?
    plz ur guidance about what i have mentioned in bracket bcoz i dont understand it at all
  • govee Aug 14, 2008
    what else can be done to get the best performance on my PC.
    plz tell me something interesting which can be AMAZING.
    plz show/tell me something AMAZING so that my friends have to be proud of me.
    i want to add some cooling systems.
    wot d ya think will be the best for my motherboard.
    wot kind of accessories,cooler,fan I can add---plz keep in mind that I want everything best.& with best performance.
  • govee Aug 15, 2008
    i want best performance
    reliability 26%(bad)
    performance 26%(bad)
    Error resistance 26%(bad)
    Temperature (at least 110 "F (horrible))
    what to do to get 100% and least Temperature.
    wot to do ??????
    Reliability 26%(bad)
    Performance 26%(bad)
    Temperature 110"F (Horrible)
    wot to do to get 100% in each and least Temperature as well.
  • govee Aug 24, 2008
    i want Drivers of ROADSTAR Racing Wheel FOR USB.
    can i get it ?
    i m asking it bcoz i have surfed d internet but couldn't get it anywhere.
    could u please help me.
    mind it....it's not a gamepad ...it's a Steering Wheel.
    plz help me out.
  • 1,031 Answers
It can support up to 2GB ram maximum FSB 533/400MHz,
Memory Supported RAM Technology: SDRAM, DDR SDRAM
RAM ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600, PC100, PC133
Posted on Aug 10, 2008
I have motherboard Asrock M266A R3.0 I need to know the max of ram able to work at this mother
2 x DDR, DDR266/200 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Mar 25, 2014 | Asrock Computers & Internet
I want intel asrock 845 motherboard driver pls give me the link for free download
Here is the link you required,
1. www.asrock.com/mb/faq.asp?Model=P4i45G
2. www.chipdrivers.com/driver/motherboard/asrock/845gv-m
3.www.downloadatoz.com/driver/.../4696,asrock-p4i45gv-motherboard-driver. html
Let me know that i Fixya the problem.
Thanking you,
B.Krishnamacharyulu
Nov 08, 2010 | Intel D845GVSR Motherboard
RAM Slot does not recognize more than 512MB ( 184 )
Consider updating your motherboard bios.
http://www.asrock.com/mb/download.asp?Model=K7VT2&o=BIOS
Also make sure that your memory is correct for this system:
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
Jun 26, 2010 | Asrock K7VT2 Motherboard
My motherboard is asrock p4i45gv, its always blue screen if install some aplication, why???
Well I think it's caused by a dusty RAM memory or defective memory causing a parity error in the first 64 kb of that RAM.
Take it/them out & clean with a student eraser or light alcohol. If prob persists pls replace RAM
Hope it helps u my dear
Feb 07, 2010 | Asrock P4I45GV...
ASRock N68PV-GS Ram startup issue
Hello there:
it seems like you have got a compatability issue here. please contact a local computer repair shop or the manufacture of the board to find out if the memory is compatable with yoiur system
Jul 22, 2009 | Asrock 845GV (P4I45GV) Motherboard
How much ram does asrock p4i45gv support?what is the maximum ram capacity i can upgrade to???
- 2 x DDR slots, DDR333/266 non-ECC, un-buffered memory
Jul 07, 2009 | Asrock P4I45GV R5 Motherboard
MoBo turns off after booting
hey, this victor from kenya. Have you confirmed that the heatsink n coler fan is firmly attached to the motherboard? suc error is usually as aresult of non efficient cooing systems.
Also reapply the cooling compound. Use methylated spirit to clear tha old application on the surface of your processor.
If this 2 fail,confirm that you are using a compartible processor to the asrock motherboard.
Jun 27, 2008 | Asrock 845GV (P4I45GV) Motherboard
Sound driver problem
Here:
http://www.asrock.com/mb/download.asp?Model=845GV-M
Mar 20, 2008 | Asrock 845GV (P4I45GV) Motherboard
2 x 2GB Kingston CL5 detected as 1 GB each one
Ok, I got it, Ur motherboard supports upto 8GB DDRII Dual channel
Try using these RAMs on other slots of the board to check if there is a problem with RAM Slot (As there are four slots on ur board).
If no success, try using RAMs on some other system to confirm whether problem is with RAM or Motherboard.
Mar 15, 2008 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
PC Getting restart after installing RAM of different speed
1. Make sure the memory is seated firmly in the motherboard and the clips are fastened. 2. When it boots up try to hit the key to get you into the CMOS setup screen. If you make it in the CMOS setup save and exit. 3. Follow the motherboard instructions to clear the CMOS. Involves jumper or removing battery etc.. the process varies with manufacture and model. If it starts working check the capacitors on the motherboard to see if they are blown on the bottom, leaking brownish gunk or bloated. 4. Put the old memory back in and see if it works normally. May not be compatable or backwards compatible.
May 15, 2007 | Asrock 845GV (P4I45GV) Motherboard
Asrock P4I45GV R5 Motherboard Logo
379 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
