Samsung YP-Z5. Unable to navigate or scroll through menus will only play music from the 1st file. Any ideas appreciated even if it's a case of sending it back to possibly be repaired? Thanks for you time
  • Tiggsman Aug 11, 2008
    Thanks, I tried both of your suggestions, unfortunately niether worked.
    Genius:
  • 3,422 Answers
Try reseting your player by removing the battery from the back for 10min and then install it back again.
Posted on Aug 10, 2008
  • Priya darshan Aug 10, 2008
    If this doesn't fix the issue then just press and hold the reset button at the bottom, with a paperclip for 20 seconds.The reset button is nothing but a very small hole.
    Goodluck.
I have a Samsung YP-Z5 MP3 Player - I can hear the music, but not the actual words to the songs - like karokee on my MP3 player
hey its in the file it self, maybe the lyrics is actually wrong at all, its not in the player.
Sep 30, 2009 | Samsung YP-Z5 MP3 Player
System Error on yp-z5
I have resolved my problem by using a firmware updater specific for YP-Z5
You can download it here: http://dump.ru/file/540116/ it is called MCL.rar
After that :
1_install the firmware updater
2_hold the center button while connecting your player , in order to put-it in recovery mode
3_wait for the program recognizing the player and updating it
for me , my player was totaly bricked and now it works very nice
Regards
Nov 23, 2008 | Audio Players & Recorders
MP3 driving me mad
i cannot turn on my samsung 1G mp3 yp-1 after last recharge.
How can i turn it on or reset it?
Mar 15, 2008 | Samsung YP-Z5A MP3 Player
Mtp sync problem
Try formatting the device
Nov 21, 2007 | Samsung YP-Z5 MP3 Player
Samsung YP-Z5
From my experience this is a hardware fault with the touchpad. Luckily you can buy a faulty player on ebay and replace the touchpad - make sure the fault on the faulty one is not the same!
The player is is easy to take apart and the touchpad easy to replace.
Nov 20, 2007 | Samsung YP-Z5 MP3 Player
Samsung YP-z5 won't connect to the PC!
This might help getting it connected to the computer.
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Sep 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Mp3 Not Being Recognised and Samsung Media Studio Not Installing
As with any issue with this type of digital device, you should always "RESET" the device first (little micro switch - next to the USB port, or on back)...press with a pin (or similar) for 2-3 sec's. I then suggest you fully 'remove' any Samsung Media software (via add/remove programs under control panel). Re-boot your pc, then connect your Z5 into a know working USB port on pc. See if it installs the Z5's driver correctly (ie starts communicating). If this gets it going, you must now download the newest firmware from Samsung's website (download centre), and then save the files into your Z5 (ie overwrite the old firmware). If this fails, then try Samsung directly for further intructions. Good luck.
Jun 18, 2007 | Samsung Yepp YP-Z5QB MP3 Player
Keeps restting itself
Firstly, try "re-setting" the Z5 (ie micro switch) first. If this doesn't resolve, then firstly save a backup of all your files...then use the 'format' function (ie open My Computer, then open the YP-Z5 folder, then look for the Format function), which will clean out your entire memory, including hidden files. Then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your Z5. Always update your Z5 with latest firmware (appropriate with your Windows OS). Good luck.
Mar 06, 2007 | Samsung Yepp YP-Z5QB MP3 Player
 Grubhead
Grubhead
