SOURCE: Access to Bosch dishwasher pump
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the machine over on its front, using a heavy blanket or pad to protect the dishwasher's finish. Remove the back service panel. The pump is usually located along the bottom. Good luck!
SOURCE: Bosch Dishwasher
carry out a reset.
This should reset the board back to factory settings,
Deep Diver
SOURCE: Bosch 24 in SHU66C05UC/14
http://www.applianceaid.com/boschDW.html
i hope this link helps you diagnose your problem
Thank you for using Fixya
SOURCE: Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
