Question about Jensen VM9510 Car DVD Player
No video when driving
I can't watch tv or a dvd while driving. how do i solve this problem?
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 10, 2008
CAN I DIRECTLY CONNECT SMSUNG DVD WRITE MASTER SE-S204N TO TV SONY BRAVIA AND IF CAN HOW
YEh A DVD- writer can always act as a DVD player.
Do you want to write a movie going in the TV to a DVD or watch a DVD on the TV?
If you want to watch it on the TV yeh you can connect this directly to the TV and select the AUX mode (your Tv might be having different input modes such as - video 1, video2, HDMI, etc)
May 30, 2014 | Samsung Model Se-s204 External Dvd Writer...
I could hear the dvd but i cant see nothing.
that is a lockout so you will not drive around and watch tv. You need to hook up the parking brake wire from the radio. there are ways around it if you want to drive around and watch tv
Feb 06, 2010 | Car Audio & Video
"WARNING STOP WATCH WATCH VIDEO" and no sound
Follow the following steps to overcome this problem:
  1. Locate the "Brake" wire (usually the pink wire).
  2. Connect the "Brake" wire to a negative point, e.g. body of vehicle.
  3. Test by playing a DVD and your problems have been solved.
Sep 24, 2009 | XO Vision XOD1735 Car DVD Player
The action description for the visually impaired is on when I try to watch videos. Don't know how to get rid of it. Is it a TV or VCR problem? It's an old Sylvania TV and an old Electrohome VCR
Problem solved. It was the video tapes themselves..they turned out to be from a special section for the visually impaired. I got used to it and watched them anyway. :-)
Sep 07, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Using DVD+R i can burn an audio/video which plays
Tha's because not all dvd players can read DVD R+. Get a DVD R- and you will see how nice you can watch the videos in your DVD Player.
Aug 15, 2009 | Lite On SOHW - 1633S (show1633sbk)...
CONNECTING DTV CONVERTER AND STILL USING DVD PLAYER
Get a set of video cables to connect the DVD player to the TV.
Then follow the numbered instructions in this post to connect the DVD player, and use your TV remote to switch the video mode when you want to watch a DVD, then switch it back when you want to view TV.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 24, 2009 | Toshiba 32AF42 32" TV
Playing DVDs on Laptop through the TV
Here's what's happening... software companies like CyberLink subscribe to the Macrovision requirements for playing DVDs and protecting copyrighted materials.
Macrovision has approved numerous video cards for what they call "TV Out" which allows the movie to be displayed on your TV.
Unfortunately, your Dell Inspiron does not have a Macrovision approved and supported video card in it, so it gives instructions to the computer to disable TV Out and not allow it to play anywhere besides the computer.
Jan 06, 2009 | LG DRN-8080-B for Dell Inspiron Series DVD...
See videos wile drive in AVH-P5000
These DVD systems have a wire that is connected to the parking brake and gets grounded when the parking brake is engaged to prevent the driver from watching video while driving. Once you engage the parking brake, you can watch the video. The video output still works for an external monitor while driving. These are precautions to keep you safe while driving. somebody watching a video while driving is much more likely to get into an accident.
Jun 16, 2008 | Car Audio & Video
Can tune mitsubishi HS-651V video player/recorder to watch TV.
Hi Jaco, Have you fed in your Antenna / cable into the Rear of the VCR? And if your VCR has a Input selection switch, just check input to Tuner. You will get Blue screen if input selction is not Tuner but Camera / External source. If this does not solve your problem, then there is no Input selection happening.
Apr 06, 2007 | Mitsubishi HS-U448 VCR
Watching videos on a computer
Yes. DVDs are easy as you probably already know, you just need a DVD capable drive and appropreate software to play. VHS tapes are another matter altogether. You'll have to purchase something that will convert the analog signal from the VHS player to a digital signal your PC can use. I have a device I use to convert VHS tapes to DVD (ADS technologies) I could use to watch tapes but the software leaves a lot to be desred.
Feb 20, 2007 | Samsung DVD/VHS/MP3/SVHS Playback
Jensen VM9510 Car DVD Player Logo
97 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
