I have a Bush DVD15TV, when I insert a dvd it says 'loading' then changes to 'no disc'. Can you advise please? I have tried to put a lens cleaner in and it does the same thing.
  • 1 more comment
  • polly12 Aug 10, 2008
    This is a combo dvd tv.
    Hi Brian,
    Thanks for your reply - I have tried lots of discs - new, old etc. They are all doing the same thing.
    Thanks
    I'm not sure if it is a sealed unit - I'll have a look, thanks.
  • 319 Answers
Have you tried using another disc?
Sometimes DVD-r discs will not read properly, or may be defective.
Try to use another disc, one that is clean!
Regards,
Brian
Posted on Aug 10, 2008
  • Brian Berndt
    Brian Berndt Aug 10, 2008
    OK,
    One possiblity is that the drive spindle motor is not working, which causes the DVD not to spin, which will cause the lens to not "see" anything.
    On a combo unit, it will be hard to tell, unless you can open up the player to see what is happening when you put in a disc.
  • Brian Berndt
    You should be aware that opening up a unit like this could expose you to harmful electrical current, whether the unit is plugged in or not!
    One other possibility is to insert a disc. Shut the DVD drawer, wait for the error message. Then unplug the unit for at least 15 minutes. Then plug back in, and try to "play" the disc.
    Otherwise, it appears that this unit may be at the end of it's useful life (at least the DVD player).
    Brian
My dvd player has just stopped playing disc's? I insert a disc, it loads up as the little circle comes up, saying loading. Then it says bad disc.It stops. Does anyone know what could be wrong here?
Couple things could be. I've found : the disc can be dirty, wipe it off. Or if its damaged the lens won't read it.
What usually helps the most is to put a lens cleaner in the player. they sell them. I only have a CD cleaner ( prob called lens cleaner). It still fixes it for me.
Jul 20, 2015 | Televison & Video
My 2 1/2 year old LG dvd/vcr recorder will play some dvds but will not play others. It says unknown disc. I was told to try a lens cleaner; I bought one and the lens cleaner says unknown disc as well. ...
Your DVD /VCR says unknown disc because the
dvd which you have inserted is not of the supported format by player.
If you insert unsupported formats only it will say as unknown disc.This is not related with disc cleaners.
Please insert the supported formats and it will play the disc.
Thanx
Jul 31, 2010 | LG Televison & Video
When i put a dvd in it the screen just jumps.
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is the cause of he problem and not battery.
The lens reads the files/data on the disc inserted into the player and once the lens is weak, there is no way it would load discs.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Apr 22, 2010 | Insignia IS-PDVD10 Portable DVD Player
When disc is inserted, the window show loading for about 60 seconds, then tray comes back out. have tried all type of discs, same result. the vhs side works fine.
TRY A LASER LENS CLEANER IT IS A DISC WITH TWO PIECES OF LIKE FELT ON IT SHOULD COME WITH CLEANER JUST PUT IT IN AND PLAY TO CLEAN THE LENS IF THE LENS IS DIRTY IT WILL ACT LIKE ALL CDS ARE TO SCRATCHED TO PLAY
Jan 19, 2010 | GoVideo Go Video DVD/VCR Combo
Disc won't load. Get
there a problem of the DVD disc...
try to insert another disc..
if "wrong disc" message appear again...
insert the Disc Cleaner of the DVD.. so that you can clean the lens surface of the DVD Player...
Oct 23, 2009 | Televison & Video
I am electronics tech: I have a JVC.XV-N322 DVD PLAYER. Insert any dvd &vcd disk.rotate the disk somtimes but no playing.''NO FILE'' display on front panel. ...
Clean optical lens with good quality cotton bud and check is it playing disc?
Also check sled motor and spindle motor that can cause no file problem, put drops of WD40 contact cleaner in motor bush where shafts are coming out.
Sep 10, 2009 | JVC XV-N320 DVD Player
"no disc" pops up when dvd is inserted into Mintek dvd-1600
The laser lens could be dirty. Try using a reliable CD/DVD lens cleaner kit like the Belkin CD DVD cleaning Kit but if that does not work the player could be defective or already broken. I would shop for a better-name brand player on eBay so that I won't spend too much on another player.
Aug 23, 2009 | Mintek DVD-1600 DVD Player
DVD player doesn't play when disk is inserted
may be a problem with your lens try DVD disc cleaner. This cleaner looks just like a disc with some extra little brushes on its surface. Some DVD cleaner kits even come with supplies to clean and modify scratches on your discs.
please leave a fixya rating
Apr 25, 2009 | Televison & Video
Dvd player
Not a disc cleaner you need but a lens cleaner. If that does not work then there are electronic or mechanical problems and most likly not worth repairing.
Sep 30, 2006 | Bush DVD2038 DVD Player
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Electro Med Services...
