Question about Singer 7462 Mechanical Sewing Machine
Bobbin cotton breaking on sewing machine - Singer 7462 Mechanical Sewing Machine
  • 876 Answers
You can loosen the tension on your bobbin some. Be careful not to loosen too much. You do this by turning the screw counterclockwise. Also your needle may have a snag on it. occasionally, a needle can be bad.
Posted on Aug 10, 2008
MACHINE ONLY SEWS A COUPLE OF STITCHES THEN IT CUTS OFF THE UPPER THREAD
check your cotton strengh and also your bobin tension other wise it will keep on breaking
Apr 08, 2017 | Sewing Machines
Why does the needle keep breaking?
not really sure ,have you made sure there is no cotton caught in the bobbin case ,also are you using the right size needle x
May 21, 2015 | Brother XL-2230 Mechanical Sewing Machine
Singer featherweight 11 cotton keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 28, 2013 | Singer Featherweight II 117
THE COTTON KEEPS ON BREAKING EACH TIME I WANT TO SEW
The needle thread breaks
8. try a different thead
9. try adjusting the top thread tension
Dec 20, 2012 | Sewing Machines
Tension problem old singer sewing machine
try rethreading the machine top & bobbin to make sure the thread is not caught
somewhere
change the needle
if the tension dial does not respond then the dial may need to be replaced
Apr 12, 2012 | Singer Sewing Machines
My Bernina 1090 keeps breeaking the bottom thread. It sews about 10 inches and breaks. I take out the bobbin and rethread and it sews a while but still breaks. I have had it in for service 3 times and...
Assuming your bobbin tension is not too high, make sure the bobbin case is clean on the inside - use a cotton bud to clean it out. Are you using good quality Bernina bobbins - if not you're on a hiding to nothing ! It is possible that the bobbin case is deformed, but most likely your service man has set up the tensions too high ... look for someone else !
Jan 21, 2012 | Bernina Sewing Machines
Tension is too tight unable to loosen cotton breaks Maybe needs a service??
Before you do anything else unthread and rethread the machine again. Sometimes the thread gets hooked on something or wrapped around and will cause it to break. Of course do check the tension again too. Is it breaking when you pull on it before it goes through the needle?
If it is breaking when sewing then it could be that the bobbin tension is too tight.
May 27, 2011 | Janome Mini Compact
Bobbin tread is loose when sewing on cotton material Have adjusted tension, it is on 9. It is fine when I sew denim, which I sew a lot but I am trying to sew cotton now. I have cleanned machine, changed...
Have you checked not only the top tension but also the bottom (bobbin) tension? Top tension is usually a lever wheel etc on the machine (depending on model). To tighten the bobbin tension you need to tighten the small screw on your bobbin casing.
I don't suppose it could be as simple as this?
Jul 07, 2010 | Kenmore Sewing Machines
The thread in the lower looper breaks frequently I spend more time threading than sewing
Try replacing the needle. It may be bent. I use polyester/cotton thread in the bobbin as it is stronger and resists breaking. A loose or a tight adjustment on the bobbin holder can also cause breaking. Check with a service shop for this one if you are not familiar.
Mar 28, 2010 | Janome Memory Craft Compulock
Cotton is not threading up from bobbin.
Check your needle to be sure the flat side of the shank is facing the back of the machine.
Make sure the bobbin is inserted so the cotton is threading from the bobbin in the correct direction and through the correct guides.
Mar 11, 2010 | Janome 6019QC Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
32 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
