Question about Memorex Televison & Video
Tray won't open on my MRX-530L CD/DVD recorder
  • 319 Answers
Hi
Turn off your DVD player. Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire, like a paper clip,into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs. Good luck, Brian
Posted on Aug 10, 2008
    Genius:
  • 3,422 Answers
HI,
Please unplug all cords of your dvd player for 30min and then plug it back in.The tray will open.
  • Priya darshan Aug 10, 2008
    If you need anymore help let me know.
    Please don't forget to rate or accept the solution.
  • Memorex Master
  • 13,433 Answers
There is a small hole in the front you can use a needle to push the tray open.
    Guru:
  • 1,894 Answers
Leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
  • dewan nafees ahmed Aug 10, 2008
    Master:
  • 763 Answers
Maybe the push ejection got the problem. it must be stuck inside. go to your nearest technician. they have tools. so that they will help you fix the motor inside your dvd recorder. just always put a cd or dvd with correct size and weight. hope that helps!
CHARCOIS
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Installed MRX-530L-16 and cannot get computer to recognize...any suggestions? Thanks, Larry
Make sure you can see the drive from BIOS is the very first thing you should do.
If the BIOS cannot see it then it will probably be a cable issue.
Double check both the data cable and the power cable to the drive and if you ave spares then swap the data cable out for another to test.
MOST IMPORTANT
make sure the jumper is set to CS or SLAVE as this is an IDE drive and that needs to be set first.
I am going to bet that this is a second drive so you also need to make sure that the first drive is set to MASTER or CS (cable selelct)
two drives cannot be master or both slave they have to be one or the other
CS is the only time both can be the same.
Feb 14, 2011 | Memorex (32023292) DVD±RW Dual Layer...
DVD burner
Depending on the type of football game it is, the software is seeing some sort of copyright on it. If it is from the NFL, then you won't be able to put that video on DVD.
Mar 30, 2009 | Roxio Easy VHS to DVD for PC
Dvd recorder tray won;t stay in,,, even without the cd or dvd
is this the 360 cause i have never heard of a loose tray, try to take it back to where you bought it.
Jan 10, 2009 | Microsoft Xbox 360 Console
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Tray won't open in my MRX-530L CD/DVD recorder
This is a computer drive right?
Is it still covered by warranty - if it is let the repair guys deal with contact the maker or your dealer for warranty service, should be free.
if the drive is out of warranty you can safely remove the drive from your computer, unscrew the generally 4 screws in the bottom, take the drive apart, remove the cd / dvd and see what is blocking the tray from opening. By the way does the tray try to open at all?
Aug 10, 2008 | Televison & Video
Televison & Video Logo
543 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
