My phillips CRT TV won't turn on - when I switch it on with the remote, the power light doesn't illuminate and a strange squeaking noise comes from within - it sounds like a bird chick squeaking at around 1-2 squeaks per second constantly - any ideas please?
  • 8,617 Answers
Sounds like the HV generator needs replacing. You can get a replacement at the following link. If your not sure which one your model uses, leave them a email with the model number of your set.
http://servicemanuals.vstore.ca/
Posted on Aug 10, 2008
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
Problem with a Phillips 32 in TV green light blinking
There is some problem with main board. Seek tech support
Jun 02, 2012 | Philips Televison & Video
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
Need code to set dish remote control for Hair tv HTFR20R21------FDA/DHHS
We would be happy to help. We currently do not have any codes specifically for your Haier TV, we would recommend performing a power scan. If there is a code that is compatible with your TV the power scan will find it.
Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jan 16, 2011 | Haier HTF201 TV
I have purchased a insonic tv master remote and it didnt have any instructions with it. I need to program it to my phillips tv
press tv. then press the red and select at the same time light will blink twice enter 0081 if tv turn off press select then tv! if it don,t turn off press tv then select and red together light blinks twice! now press power on and off switch until tv turns off when it turns off press select to store code
Sep 13, 2010 | Televison & Video
What are the tv remote codes for Prima tvs when using universal remote controls like those owned by Dish Network?
We'rehappy to help you with programming your DISH Network remote to your Prima TV.Start by pressing and holding the TV button located on the top of your remoteuntil all mode button back lights come on, and then release. Use the numberbuttons to enter the codes for your Prima TV; here are some of the codes wecurrently have for it: 674, 653, 673, 912, and 842. Press the pound (#) button.To check that the code works try several different functions on the remote tomake sure it will properly operate the TV. Remember that some codes may not becompatible with your TV. If this is the case, try the other codes listed foryour Prima TV until you find one that is compatible with it. Ifnone of the above codes worked we recommend performing a power scan: Power scan instructions:
Step 1:
Step 2:
Step 3:
Step 4:
After doing the power scan please remember to put the remote back into SATmode. We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
Jun 08, 2010 | Prima CV2011 TV
Phillips 32" HDTV power light blinks green but wont turn on
the problem in the main power supply it depends of the kind of faillure but normaly to repair it not very expensive
good luck
Aug 23, 2009 | RCA F32650 32" TV
Tv making strange noise
Then just turn it off, if the popping irritates you.
As for why, I guess it just keeps turning on and off the speakers when it turns the light on and off...
May 19, 2009 | Panasonic Televison & Video
Televison & Video Logo
378 people viewed this question
Top Televison & Video Experts
Electro Med Services...
