Servis m6160w logic 1600 tripping rcd
Hi there i have a servis m6160w logic 1600 which trips the whole house as it goes into spin mode, I believe this may be the brushes in the motor or does it have an induction motor please can someone help. thanks in anticipation .les
  • lessjo Aug 10, 2008
    thanks guru, i have had a good look, tried motor without earth and it worked fine,connected it back and it tripped,of closer examination I have found a small leak on the outer drum directly above the motor so that appears to be causing the short,thank you again for your help
    President:
  • 1,462 Answers
Many servis have an induction motor but later models have a brush motor.
worn brushes will not cause an earth fault. suspect part of the motor windings are down to earth. also possible you have a leak in the tub or door gasket so that on spin, water is thrown onto an electrical item
Posted on Aug 10, 2008
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Advice on RCD tripping
yes
an accredited electrician can test the circuits for insulation failure , vermin shorting across active / neutral/ earth points and the rcd itself
it is not a diy job
May 12, 2017 | Ovens
Zanussi washing machine trips rcd on spin
Hi Ian.
I am assuming your RCD is fitted in your consumer unit (fuse-box)?
If so, then the chances of this being the cause is minimal. The RCD trips wen electricity is not balanced between live and neutral wires - which means some is leaking out to elsewhere - which it shouldn't because it is dangerous.
It would have helped if you had indicated how old your machine is, and how much use it has had but I am currently leaning towards the motor have several winding options that kick in (or not) depending on the spin speed. It would therefore be a motor fault, or something as simple as the brushes are disintegrating (which is often accompanied by hesitant and intermittent behaviour from the motor). These types of faults mean that some of the electricity may be leaking to the motor casing and then to earth.
I would recommend you call an engineer or if you have decent DIY skills, locate a replacement motor (ebay or the likes) and swap it out.
Good luck
David
Dec 15, 2013 | Zanussi Washing Machines
Essential 1600 spin
Hi Ian.
It would have helped if you had indicated how old your machine is, and how much use it has had but I am currently leaning towards the motor have several winding options that kick in (or not) depending on the spin speed. It would therefore be a motor fault, or something as simple as the brushes are disintegrating (which is often accompanies by hesitant and intermittent behaviour from the motor). These types of faults mean that some of the electricity may be leaking to the motor casing and then to earth.
Good luck
david
My house fuse box is fitted with a master RCD. A feed off a lounge socket goes threw the wall and feeds an external weather proof RCD box which when switched supplies my garden lights. If a garden light...
Appears the main box RCD is just as fast as the secondary RCD and it sensed the same fault that triggered the outside unit and it didn't wait around to see if that outside unit did the job.
Sep 07, 2013 | Kitchen Ranges
Xerox Phaser 8550 tripping RCD on warm up
IF the warranty is still in effect, call for service.
IF no warranty, then check the heaters for the solid inks.
Probably a bad element, or a shorted element.
Unless you are skilled with electrical meters, V-O-M type,
this could be dangerous.
DO NOT ATTEMPT to troubleshoot this with power on.
IF you can use a meter, with the power OFF,
check for continuity and resistance with multi-meter set to Ohms.
BE CAREFUL!
Electricity can KILL!
Jul 27, 2012 | Xerox Phaser® 8500, 8550, 8560, 8560MFP...
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Servis easy logic 1600 wont spin
servis easy logic 1600 wont spin just moves the drum half a turn and stops but repeats all the time
Aug 17, 2008 | Washing Machines
AEG Lavamat W1450 2 years old,
possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Oct 24, 2007 | AEG Lavamat W1450 Front Load Washer
Washing Machines Logo
341 people viewed this question
Top Washing Machines Experts
