Question about Panasonic Audio Players & Recorders
Since a storm the dab function on my SC-EN29 COMES UP DAB AUTO SCAN F26 DAB DDOWFIC i cannot get any stations
  • 2,071 Answers
It is a loose connection or cold solder and cleaning problem this is the main caused of no sound..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 10, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Dab signal
I suggest you scout around the neighbours for a DAB you can borrow to test the signal in your usual place. Your own radio could be faulty.
One of my DAB radios worked fine on FM even though one day it just stopped working on DAB for no apparent reason. The board to repair it is priced not to sell...
Sep 17, 2017 | Audio Players & Recorders
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
I HAVE A SC-HC30DB SYSTEM AND IT'S NOT LETTING ME IN THE DAB MENU,DAB NOT WORKING ALL WORKING OK OTHERWISE.
I had the same problem - you can fix with a system reset. Unplug the unit at the wall and wait 2-3 mins, then plug in and switch on while holding the power button - the display will be blank for at first, but will eventually display '---------------------'. Release the power button and switch the unit on as normal. Press the Dab button and the unit will start to auto-search for channels. Give it a few minutes and you'll be back in action :)
Chris
Jun 29, 2011 | Panasonic SC-HC30 Audio Shelf System
DAB preset is stuck on chanel 1. Machine will not allow DAB to retune or move to another chanel
Have you tried pressing the play mode button to change from preset to station list which will allow you to view all stations available.
Nathan.
Jan 14, 2011 | Panasonic SC-HC30 Audio Shelf System
Retune Panasonic SA-EN38DB DAB radio + ipod dock
Original manual found - note the Model No. is listed as SC-EN38DB i.e. complete system (main unit = SA-EN38DB; speakers = SB-EN38; remote control = N2QAYB000245):
"Press and hold (PLAY MODE) until 2DAB AUTO SCAN' appears. When a frequency is tuned by Auto scanning on this unit, the ensemble corresponding to the frequency is displayed for approximately 2 seconds"
Nov 17, 2009 | Panasonic Electronics - Others
DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Feb 22, 2008 | Audio Players & Recorders
Acoustic solutions pd2 dab radio
press and hold the dab/fm button for 2 seconds, then press enter, it should say system reset, then re scan by doing the auto scan button , job done .. kev
Dec 11, 2007 | Audio Players & Recorders
56 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
